Like Tree1Likes
Xray T1FK05
Old 09-29-2005, 10:48 AM
  #3796
teamtamale has the two degree rear hubs. Far better than the xray aluminum.
mtc3od is offline
Old 09-29-2005, 10:57 AM
  #3797
ALL APPROVED's Avatar
Originally Posted by YR4Dude
Try going to: www.dinball.com
They have the parts you're looking for. However they don't have the ones I am looking for:
Battery strap
2deg rear alum hubs
If anyone knows where I can get those, I would appreciate it.
tqhobbies 407-339-1899 ask for tim if they don't have it they will get it for you
ALL APPROVED is offline
Old 09-29-2005, 10:59 AM
  #3798
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Thanks I'll try that.
Just found the battery strap at http://shopping.rcmodel.hk
They also have other optional parts as well, including a carbon bumper plate.
YR4Dude is offline
Old 09-29-2005, 11:01 AM
  #3799
your welcome
they have a hole wall of parts ..plus rite now there getting ready for the nats so they have lots of xray parts in stock
Old 09-29-2005, 11:54 AM
  #3800
Scrad's Avatar
Trader Rating: 16 (100%+)
Tim, your back to an xray? I still have your old gold one, but it's setting in the closet collecting dust.
Scrad is offline
Old 09-29-2005, 12:51 PM
  #3801
thats what it was doing in my closet also. I should of keep all of my spare parts.
The rdx is nice but I had to go back to xray because the rdx is like up and down . its good 1 minute the next its out of control.
Old 09-29-2005, 04:16 PM
  #3802
Scrad's Avatar
What happened to the TC4?
Scrad is offline
Old 09-29-2005, 04:47 PM
  #3803
the_barbarian's Avatar
Battery strap
2deg rear alum hubs
have a look here
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
http://www.rcboca.com/manufacturers....erid=66&page=4
http://thercshack.com/index.asp?Page...OD&ProdID=2180
the_barbarian is offline
Old 09-29-2005, 05:51 PM
  #3804
mike ivy's Avatar
Trader Rating: 50 (100%+)
I have a question my Xray T1 FK '05 when Im entering a turn the car pushes is there any way to get more steering entering the turn? here is my setup:
http://www.teamxray.com/xforum/xform...2&setup=t1fk05
mike ivy is offline
Old 09-29-2005, 05:54 PM
  #3805
hpipro321's Avatar
start out with a slightly tighter diff then but one more degree of toe and you should be fine
But do not over tighten the diff ( s)
hpipro321 is offline
Old 09-29-2005, 06:11 PM
  #3806
Jimmy Morris's Avatar
You can try leaning the font shocks in one hole or looseing the rear diff.
Jimmy Morris is offline
Old 09-29-2005, 06:17 PM
  #3807
Scho's Avatar
http://www.teamxray.com/xforum/xform...3&setup=t1fk05
Give this a try.... works very well
Dont add more toe to the rear... 3 is far too much already, ecspecially for stock.
HTH
Scho is offline
Old 09-30-2005, 07:38 AM
  #3808
sold it to a friend ..
Old 09-30-2005, 07:48 AM
  #3809
ok this is alot but its all going to depend if your track is smooth or ruff. This is for smooth to med. I haven't ran it on a ruff track yet.
no front or rear stand
down stops 1 - 0
3 degree caster
white with yellow springs
2 hole front 3 hole rear pistons
rear toe 2.5
this set up works great no push and med to lots of steering
Old 09-30-2005, 07:50 AM
  #3810
Hey, Cardinal=Xray guy. Super fantastic!
