Like Tree1Likes
Xray T1FK05
Old 09-22-2005, 05:33 AM
  #3691
FlyinRazorback's Avatar
Originally Posted by Homer Allman
Where do you guys get your parts for this car?
You don't need parts for it Homer.......but if I do, I use my LHS
FlyinRazorback is offline
Old 09-22-2005, 11:07 AM
  #3692
lbckevin's Avatar
Trader Rating: 107 (99%+)
In 3 months with the car....I have only replaced only the front blades once. They have a tendency to wear out with a front one way.
Kevin
lbckevin is offline
Old 09-22-2005, 11:32 AM
  #3693
motorhead's Avatar
want to know if spoll is still good running on carpit or sould i run
a one way / what are most guys running.track is med size
motorhead is offline
Old 09-22-2005, 12:07 PM
  #3694
Roger's Avatar
Kevin
If you use the spool, you'll replace them more frequently. With the front oneway, you'l have good life with them depending how often you use your car.
My reccomendation is to keep some extra blades in your parts box.
Roger is offline
Old 09-22-2005, 01:32 PM
  #3695
Homer - Mimi's, Hobbytown USA, Speedtechrc, KThobbies, RCAmerica is where I do must of my shopping for the Xray. But like a few have said the car is really durable.
Mark
munrath is offline
Old 09-22-2005, 02:50 PM
  #3696
hpipro321's Avatar
Kevin
ive changed about 4 sets of fronts. I am also runing a one-way
hpipro321 is offline
Old 09-22-2005, 03:08 PM
  #3697
motorhead's Avatar
so one way is better on carpit/ correct
Old 09-22-2005, 04:36 PM
  #3698
Midnight's Avatar
Trader Rating: 87 (100%+)
The best and cheapeset way to get parts is thru speedtechrc.
Midnight is offline
Old 09-22-2005, 04:48 PM
  #3699
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Hi,
I'm just looking to see if anyone has some experience in setting the 05 up with more turning speed. It says on the Xray site that the optional rear toe in hubs helps gain more rearend turning speed. Anyone tried this yet?
Also, I am currently running stock with a oneway. I would like to know what do I need to do to set my car up for 19T or brushless mod.
Any help would be appreciated.
Thanks.
YR4Dude is offline
Old 09-22-2005, 05:00 PM
  #3700
hpipro321's Avatar
Originally Posted by YR4Dude
Hi,
Thanks.
i kno people that have and they say it has increased there turn in speed greatly. i plan on ordering the 2degree ones
Old 09-22-2005, 06:05 PM
  #3701
1armed1's Avatar
Trader Rating: 79 (100%+)
I just did the rear arm mod for running foams.
The tire still touches the shock bottom just enough to feel it when you turn the tires.
I dremmeled them inline with the rest of the arm like the book shows.
Any suggestions?
Dayton
1armed1 is offline
Old 09-22-2005, 06:14 PM
  #3702
Scrad's Avatar
Trader Rating: 16 (100%+)
That's why I didn't bother cutting the arms. Just put a washer in between the hub and rim. You could use another cone washer.
Scrad is offline
Old 09-22-2005, 07:46 PM
  #3703
Michal101's Avatar
Any suggestions?
Dayton
Dayton,
I too tried that mod and had the same problem, so I just went to the inner hole and it was fine without the issues of grinding and retapping the hole to ensure that there was enough threads to hold the shock bottom accordingly.
Mike
Michal101 is offline
Old 09-22-2005, 08:01 PM
  #3704
MClinton's Avatar
Any suggestions?
Dayton
Just shave slightly more into the arms. I had to dremel perhaps one mm into the arm above and beyond the arm's protrusion, and the shocks clear perfectly.
-Matt
MClinton is offline
Old 09-23-2005, 04:00 AM
  #3705
1armed1's Avatar
Thanks for the info guys.
Dayton
1armed1 is offline
