Like Tree1Likes
Xray T1FK05
Old 09-20-2005, 12:49 PM
  #3676
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Originally Posted by motorhead
ok guys im brain dead i have a new xray and i have it pertty dam
fast /now im getting ready for carpet and i have stock chasses
will that work ant it 2.5 mm i did get the new top deck wide
but my rear foam tires dont fit do i were do i get adaptors
or somthing to keep them from rubing the shocks
Either use the inner hole in the rear arm or you have to cut away at the arm so the shock fits. It says that in the manual and it also shows a picture.
HRCRACER123 is offline
Old 09-20-2005, 12:50 PM
  #3677
motorhead's Avatar
it not hitting the arm its hitting shock cup and bottom of the shock
motorhead is offline
Old 09-20-2005, 12:51 PM
  #3678
motorhead's Avatar
thanks guys
Old 09-20-2005, 12:53 PM
  #3679
John Tag's Avatar
Trader Rating: 42 (100%+)
You gota remove a little shock mount material on the arm to let the shock sit in more or just run the inner hole as most do...car works well with inner hole anyway...
John Tag is offline
Old 09-20-2005, 01:18 PM
  #3680
motorhead's Avatar
thanks tag i should just call you more often your a big help
only if i could get my motors like yours mine have power
but not like yous keep up the good work...
Old 09-20-2005, 01:20 PM
  #3681
motorhead's Avatar
let me say this my stocks are ripers but i have a hard time with c2 s i think
they just suck.
Old 09-20-2005, 01:44 PM
  #3682
Mororhead. You might just have some bad motors or your gearing is off. All my C2's rip hard. Cut the comm,zap the magnet,line up the brush hoods,throw in some 767's with some purple springs and watch it go!!!!
Old 09-20-2005, 02:09 PM
  #3683
motorhead's Avatar
well i did do all of that and i havent ran them yet just dynoed them
numbers ant all that great
i cut them down about 2.60 mm sould i go smaller lol
Old 09-20-2005, 05:54 PM
  #3684
axel's Avatar
Originally Posted by gee-dub
i ran the plastic ones for 2-3 race days before upgradig to aluminum (pure bling). i cannot feel a difference either static or on the track. supposedly xray is working on new shocks, can't wait to see what they come up with, hope they keep the external adjustability feature (now if we could only get some offroad 1/10 ep manufacturers to get with the times).
New xray shocks? Where did you hear this? Yeah i think i'm just get the aluminum ones for saftey in the long run.
axel is offline
Old 09-20-2005, 06:12 PM
  #3685
Trader Rating: 72 (100%+)
If you use the optional 2deg toe blocks they turn the wheel in far enough that the foam tire won't hit the shock bottom
steve eaves is offline
Old 09-20-2005, 07:12 PM
  #3686
THeGame's Avatar
Default motorhead
what tires are you running... I'm still waiting for payment.. www.paypal.com...
THeGame is offline
Old 09-20-2005, 11:39 PM
  #3687
Roger's Avatar
Originally Posted by bigdog
Roger-were did you get the alum shock bodies from I would like to get some for my car.
BIG DAWG !!! I got them from HobbyTown USA in Fremont. You can also get them at Victor's Hobbies in Newark, Cal. He currently has them in stock.
Roger is offline
Old 09-21-2005, 08:27 PM
  #3688
I was never big on gearing. I usually just experiment with diffrent pinion sizes untill the gearing is just right. Nice punch and decent top speed.
Anyway I was on gearchart.com and put in my info FK'05, Spur 116, Pinion 31 and it said my ratio was I think like 6.36. What does this mean? And how do people use this gear ratio calculator to there advantage?
Someone please clue me in..
Old 09-22-2005, 04:54 AM
  #3689
Midnight's Avatar
Trader Rating: 87 (100%+)
Think about it like this. If there is a guy thats running a TC4 and his gearing is right on, you can take his ratio and figure out yours. At my track I run a 5.69 and at Mikes in Dallas I ran a high 6. I hope this helps.
Midnight is offline
Old 09-22-2005, 05:14 AM
  #3690
Where do you guys get your parts for this car?
Homer Allman is offline
