Xray T1FK05
#3663
Anybody running the carpet front shock tower. I just installed mine because I wanted to lower ther front of my parma alfa body down lower.
It worked but now even with the front shock collers all the way up. I cant get below a 5.5 mm front ride height. I usually run 4mm. I even tried diffrent shock locations. Whats the deal....
#3664
Originally Posted by ptjonesus
I just got a xray fk05 . I am using the setup the way the book tells you to do. I have no rear traction what can I do.
#3665
#3666
#3668
Originally Posted by brians11
check out www.teamtamale.com he makes some lowered spring cups for the carpet tower...
#3673
Ge Associated spring retainers for the TC3 or TC4, put these on the front and it will allow you to get the ride height your after.
Later,
Later,
Great Idea Brians11. I will give it a try. Thanks..
#3674
ok guys im brain dead i have a new xray and i have it pertty dam
fast /now im getting ready for carpet and i have stock chasses
will that work ant it 2.5 mm i did get the new top deck wide
but my rear foam tires dont fit do i were do i get adaptors
or somthing to keep them from rubing the shocks
