Like Tree1Likes
Xray T1FK05
Old 09-16-2005, 07:29 AM
  #3631
teamgp's Avatar
Originally Posted by HarshGuy
dude, I hadn't been to the xray forums for a while, great article!!
Thanks! There are also some informative recent posts in the FAQ section thread towards the bottom of the first page and on the second page.
teamgp is offline
Old 09-16-2005, 12:47 PM
  #3632
Benro's Avatar
Hi
i have been looking at some of the setups on the xray forum and i have seen that some of the pro drivers are moving there camber links on the front shock tower to the outer most holes and i was just wodering how they achieve this as when the camber links are monted in the standard position the thread is nearly all in i just wondered if anyone new of a way around this or do i need to order some shorter turnbukles ???? Also could somone please explain to me what effects it has on the car when you run the camber links shorter and longer ????
Help would be much apreciated
Benro
Benro is offline
Old 09-16-2005, 01:21 PM
  #3633
teamgp's Avatar
Originally Posted by Benro
i just wondered if anyone new of a way around this or do i need to order some shorter turnbukles???? Also could somone please explain to me what effects it has on the car when you run the camber links shorter and longer????
http://www.teamxray.com/xforum/viewt...?p=24227#24227
teamgp is offline
Old 09-16-2005, 02:39 PM
  #3634
Benro's Avatar
Yes got that teamgp
Benro is offline
Old 09-16-2005, 04:12 PM
  #3635
hpipro321's Avatar
Yes got that teamgp
i also found gearchart.com a great place to find setups
they have it for asphault and carpet and any driver u can think of
just adding to what teamgp said
hpipro321 is offline
Old 09-16-2005, 04:54 PM
  #3636
the_barbarian's Avatar
Benro from what ive read and seen the shorter the upper control arm the faster the suspension arm will move up and down
so if it moves faster then the suspension would be more agressive more responsive making it more predictable however it would also make it harder to drive as your reaction times would also need to be faster
I would imagine shorter control arms would be better on smooth tracks and for bumpy tracks you would extend the arm
anyone is this right
the_barbarian is offline
Old 09-16-2005, 06:30 PM
  #3637
RCknight's Avatar
Default Guys...
can anyone tell me if you can get a TI screw set, ti hinge pins and/or some ti tie rods for the 05? Thanks. I was tring to check out some aftermarket bling hopups and I couldn't find anything.
RCknight is offline
Old 09-16-2005, 08:40 PM
  #3638
teamgp's Avatar
Barbarian is correct.
teamgp is offline
Old 09-17-2005, 12:34 AM
  #3639
Benro's Avatar
Thanks alot for all your help guys you have been most helpfull
Benro is offline
Old 09-17-2005, 08:41 AM
  #3640
hpipro321's Avatar
speedtech sells them but there like 70 dollars but i just use the steel ones u need to bring the car up to wieght neway
Old 09-17-2005, 01:21 PM
  #3641
with alloy hubs and titanium screws my FK04 is about 140 grams under weight on foams
I was starting to think I should just get a hardened screw set just to add some weight
Old 09-17-2005, 03:35 PM
  #3642
hpipro321's Avatar
thats wut i did to bring it up to wieght but i used the yokomo screws, i think they work better but its ur call what ur wana do
Old 09-17-2005, 03:40 PM
  #3643
Roger's Avatar
I just converted all of my xray screws to HPI steel screws. My car makes weight with foams barely !!
Roger is offline
Old 09-17-2005, 05:44 PM
  #3644
lbckevin's Avatar
Trader Rating: 107 (99%+)
I also used Yokomo screws. They are black which look great on the carbon fiber chassis. I got 24 ( 3 packages) of 3mm x 6mm.
lbckevin is offline
Old 09-17-2005, 06:51 PM
  #3645
any great pics of your black screw FK05?
will them rust as X-ray ones?
tsuiyuen is offline
