Like Tree1Likes
Xray T1FK05
Old 08-31-2005, 01:29 PM
  #3466
Rob Phillips's Avatar
I have a LCG I'm looking to trade for a FK05 or preferably a RDX. The car was only ran on carpet for a few packs and is in excellent condition. Included are a fare amount of spares and hop ups. It also comes with everything to convert it to a cmg or sd ssg. If any one is interested please PM or Email me. I have pics. Later, Rob
Rob Phillips is offline
Old 08-31-2005, 01:31 PM
  #3467
Charles Godwin's Avatar
Bit of a tip on the stripping screw thing, get some 'anti-seize copper grease' and spray a little on the end of the screw threads (the ones which go into the alum bits),this should make getting screws out alot easier
Charles
Charles Godwin is offline
Old 08-31-2005, 01:47 PM
  #3468
teamgp's Avatar
Originally Posted by raving-monkey
yeah we tried to do that asmuch as we could but a few of the screws had stripped so we drilled them out..waiting on a new screw kit.
i am going to rebuild the diff while its all apart anyway, see if needs new balls etc.
hopefully it is just tweak..will let you know.
It might also be either a bent rear hinge pin or a bent screw that secures the rear hinge pin holders to the bulkheads.
teamgp is offline
Old 08-31-2005, 01:50 PM
  #3469
raving-monkey's Avatar
Charles
one step ahead of you...me old man's got some 'copper slip'or something and he says it will stop them sticking (sounds like anti-seize copper grease)
and teampgp, thanks for the info..i will check everything like that..
thanks everyone
raving-monkey is offline
Old 08-31-2005, 01:52 PM
  #3470
hpipro321's Avatar
Charles
Heres wut i did when i stipped those piece of crap silver screws that came in the kit. I had 5 of those striped screws so wut i did was i took my handy-dandy drill and i started drilling into the center of the screw ( with a bit the size of the screw head). I kept drillin until i saw a little of the black carbon fiber then just lightly start yanking on the part, the head will break off and tada no more stripped screw, then just take the part off and twist the rest of the screw off
In the unlikly matter that the screw gets stuck in the part i.e bulk head, take a small pilot bit and drill into it and take it out with a easy out
thats how i get my stripped screws
hpipro321 is offline
Old 08-31-2005, 01:55 PM
  #3471
one step ahead of you...me old man's got some 'copper slip'or something #
Yep that's basically it
Charles
Old 08-31-2005, 06:11 PM
  #3472
howard hudson's Avatar
i am having serious problems withmy car....and as youmentioned the thrust races..it springed to mind that thismay be the problem.
thing is, mid corner to exit...on power my backend will just come out...not as though it has oversteer or anything because it was fine until i got hit up the back end real hard.
i was thinking, maybe the jolt has damaged the thrust races..the diff feels fine but i don'tknow...
anyone have any ideas?
try loosening the diff a quarter turn. TRUST me on this if the thrust bearings are ok.
the 05 does not like a tight diff. I had to learn the hard way
howard hudson is offline
Old 08-31-2005, 06:26 PM
  #3473
hpipro321's Avatar
lol i did 2 i was stupid enough to tighten it with out greasing it thinking it was pregreased from the factory
Old 08-31-2005, 06:40 PM
  #3474
thats not what I ment HPIPRO?? haha sorry had to laff. when the diff is to tight it likes to make the ass end come around. I chased set up for a long time with the same results (rear swinging out) then it hit me one day to check the diff I loosened it and all was better. the rear stays planted
Old 08-31-2005, 06:49 PM
  #3475
hpipro321's Avatar
sweet ty for info
Old 08-31-2005, 06:56 PM
  #3476
m8commando's Avatar
Does anybody know where I can fine the anodized shock bodies part#308320 and also I'm looking for part #301212 graphite upper bumper brace. anyone have any leads.
m8commando is offline
Old 08-31-2005, 11:11 PM
  #3477
okie doke, i will try that to when i rebuild it all...
hpipro321....to get out scrfews out we drilled a 2mm drill al the way down the middle of the screw (being careful to get it in the centre) and we used a 'stud extractor' which has opposite threads on, so as you tighten it, it loosens the screw and takes it out....you can get them for about £2/$2, not expensive but very handy.
Old 09-01-2005, 09:13 AM
  #3478
lbckevin's Avatar
Trader Rating: 100 (99%+)
The aluminum shock bodies have been discontinued from Xray.
They are working on a new shock design.
lbckevin is offline
Old 09-01-2005, 09:26 AM
  #3479
teamgp's Avatar
m8commando, you have PM.
teamgp is offline
Old 09-01-2005, 09:32 AM
  #3480
Pezz's Avatar
Dammit!! I was going to buy some of those shock bodies too... Oh well
-B
Pezz is offline
