Like Tree1Likes
Xray T1FK05
Old 08-24-2005, 07:11 PM
  #3331
Jimmy Morris's Avatar
The Glen Burnie store.
Jimmy Morris is offline
Old 08-24-2005, 07:41 PM
  #3332
Trader Rating: 88 (100%+)
No, its been paved since last year. All the guys are running rubber tires now.
MUDVAYNE is offline
Old 08-25-2005, 09:59 PM
  #3333
hey guys....just in case anyone is looking....I have a brand new in the package FK05 carpet chassis (3mm). I can let it go for 65.00 shipped in the USA. Also have the one-way for an 04...built but never used...25.00 shipped in the USA.
Joneser is offline
Old 08-25-2005, 10:04 PM
  #3334
dynoman007's Avatar
Default spur
what is the largest spur that will fit the fk05 that doesnt hang out of the bottom ...
dynoman007 is offline
Old 08-25-2005, 10:45 PM
  #3335
BigDogRacing's Avatar
The 116 PRS from EA Motorsports- the one I would've told you about if you have calledme and asked.... BEOTCH!!!!! I gotta order some spurs from EA too so I'll get some for both of us.
BigDogRacing is offline
Old 08-25-2005, 10:59 PM
  #3336
Originally Posted by HRCRACER123
Thanks Bigdog. I have never ran my FK'05 outside before. Does anybody have a good set-up for me.
-Rubber Tires on asphault
-Smooth low to mid bite track
-Running a spool
-Not sure what the track looks like. They always change it. I just need a good starting point set-up.
Yea, if it's low to medium then run basically the stock setup-
All references are fr/rr-
white/yellow springs
30wt w/2 hole fixed pistons both ends
3* caster blocks
front hinge pin holders- middle/bottom (that's middle front and bottom rear)
rear hinge pins- bottom/bottom
no swaybars (never on asphalt)
2/3 droop
6mm both ends if bumpy track- 5mm if smooth
shock towers- 2nd hole out/3rd hole out ( stand front shock up more if car is too hard to drive- lay rear down if car is hooked but has too much steering)
Mazda 6 or Stratus 3.0 AP
Old 08-26-2005, 04:36 AM
  #3337
with carpet chassis the 120 fits without coming out the bottom.
DJG24 is offline
Old 08-26-2005, 07:32 AM
  #3338
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Thanks again BigDog. I will try that set-up and see how the car handles with it. I know that with every car we have to make certain changes to make the car handle a little better. I really appreciate you taking the time to help me out.
My Region 1 race is this weekend at RC Madness in Enfield CT and I want to try and do good. I usually run my TC3 outdoors but I want to make a showing with my FK'05.
As far as racing on carpet. Its like night and day with these 2 cars. Driving my Xray makes me want to throw my TC3 in the garbage but it was my first touring car and has served me well for the past 2 years so I could not do it.
HRCRACER123 is offline
Old 08-26-2005, 10:02 AM
  #3339
Well then just wait til you get the FK05 dialed in- you WILL throw the TC3 in the trash!!! It has soooooo much steering and corner speed, dude you will have to relearn how to drive!!
If you aren't sure about tires, the CS27s are always a good baseline. If the track temps go above 140 then the RP36 or CS32 will work as well. ACtually the RP36 or RP30 will work fine below 140. Make sure you get some SXT traction compound or use Trinity (I hate typing that word) Buggy Grip to clean the tires after every run-at the very least.
Old 08-26-2005, 11:25 AM
  #3340
Chill Will's Avatar
[QUOTE=BigDogRacing]Well then just wait til you get the FK05 dialed in- you WILL throw the TC3 in the trash!!! It has soooooo much steering and corner speed, dude you will have to relearn how to drive!!
Bigdog is correct. I had a TC3 and this car is sooooo much better and stronger. You will like it.
Sup Bigdog. WOOOOOO WOOOOO!!
Chill Will is offline
Old 08-26-2005, 11:33 AM
  #3341
hpipro321's Avatar
i agree with chill will the car has much better corner speed and wutnot but the duability is not there if u hit something the car is so tweaked so u have to leard not to hit stuff wit that car ( still learnin )
hpipro321 is offline
Old 08-26-2005, 02:11 PM
  #3342
Rob Phillips's Avatar
Originally Posted by stiltskin
gp,
while you're on the X-ray sight, see if you can find a good set-up for Hobbytown, MD.
Ouch!
Rob Phillips is offline
Old 08-26-2005, 02:16 PM
  #3343
teamgp's Avatar
Originally Posted by Rob Phillips
Ouch!
Your two laps....err...I mean 'days' late. Try to keep up next time...
teamgp is offline
Old 08-26-2005, 03:20 PM
  #3344
Oh I guess you got jokes too, huh? That's all good, speaking of two laps down, I guess that's where you do your best racing. j/k Guy, see you on the rug.
Old 08-26-2005, 04:41 PM
  #3345
teamgp's Avatar
...see you on the rug.
Only in qualifying.
I can take it, dish it & finish it. But I rarely ever start it.
teamgp is offline
