Like Tree1Likes
Xray T1FK05
Old 08-20-2005, 11:54 PM
  #3286
wolfman76's Avatar
How do you work out the rollout???
wolfman76 is offline
Old 08-21-2005, 12:17 AM
  #3287
T1Raycer's Avatar
tire diameter x 3.14 ÷ gear ratios
exmaple: Xray FK04 whit rubber tires and run a monster
whit a monster you want a roll ou of 23:
rubber tires = 63 mm
gear ratios = spurgear/pinion x gearbox ratio
the formula:
63mm x 3.14 ÷ (128/27 x 1.77) so 63mm x 3.14 = 197.82 and 128/27 x 1.77 =8.391
197.82 ÷ 8.391 = 23.575 of rollout
T1Raycer is offline
Old 08-21-2005, 03:25 AM
  #3288
John Doucakis's Avatar
Originally Posted by rdub202
john NOOOOOOOOO!!!
i loved your car
why the change?
Well, I still have all the red parts, just experimenting with the look of the car. Maybe blue parts next time..
John Doucakis is offline
Old 08-21-2005, 05:46 AM
  #3289
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Can somebody please help me out
Can somebody help me out
PLEASE TIME IS RUNNING OUT
What would be a good price for a used FK05 in good shape ?
I don't have alot of info on the car.
I know it has two bodies.(STRATUS 3.0 and MAZDA 6)
Dual moter cooling fans
2mm chassis
I also know the car was always ran in ether 19 turn or Mod classes so it probaly has more hop ups than I listed.What would be a good $$$$$
What would be some good questions to ask the owner ?
What are the hot hop ups for this t\c ?
I am new to this hobby so any help would be awesome............
RED-LINE M03 is offline
Old 08-21-2005, 08:46 AM
  #3290
polesitter61's Avatar
Good price for a used FK05 roller..........around $250, that's about $100 to $150 under the price of a new one. It does have the cooling fans and a 2mm chassis which would run around $100 to install new. You should ask if it has any spares, if it has a front Multi-dIff, front spring steel axles, ect. Multi-diff is around $50 new, spring steel front axles are about $40 new, spares it just depends on how much it has. General rule for used stuff is 50% of it original value, I find with R/C stuff it tends to be more like 65%-75% of original value. Hope this helps.
polesitter61 is offline
Old 08-21-2005, 10:00 AM
  #3291
sands's Avatar
Putting up a feeler on selling my FOC xray. It's been converted to the factory (not '05) setup with short arms, etc. The ball suspension has been sold. Well sorted with a season or two worth of spares. I won the points season 2 years ago with it, but haven't raced since then.
Main extras are BMI chassis, spool, one-way, standard front diffs, low ratio gear set, extra springs and tonnes of spares.
What do you all think a roller should go for?
sands is offline
Old 08-21-2005, 10:04 AM
  #3292
tc3stocker's Avatar
I would say that could pull in around 2 to 250 range easy.
tc3stocker is offline
Old 08-21-2005, 07:29 PM
  #3293
rdub202's Avatar
Trader Rating: 19 (100%+)
the red looked amazing john
and to be honest, what you currently have doesnt look good, i mean its good but ya cant see too much thats different. i think neon green would be sweet. saw a xxx-s that was all greened out
and green is not a common color
you see reds, and blues, and purples but green is sorta out there
my 2 cents
rdub202 is offline
Old 08-22-2005, 07:43 AM
  #3294
teamgp's Avatar
Some pics of my car and new Stratus 3.0 All purpose.
I took away all the red parts and made it plain silver and black.
Nice pics!
teamgp is offline
Old 08-22-2005, 11:04 AM
  #3295
Shop Owner
nnick's Avatar
Don't even think about it !! The only blue FK05 in Greece is and will be mine
Nick
nnick is offline
Old 08-22-2005, 11:12 AM
  #3296
Ok Nick, respect to your efforts, won't go there then. I 'll stay with black&silver or red...
BTW blue seems to be slow...
Old 08-22-2005, 11:15 AM
  #3297
Shop Owner
nnick's Avatar
Blue isn't slow, maybe no good luck for me but not slow
Hopefully next time you will witness the "blue" power
Nick
nnick is offline
Old 08-22-2005, 12:38 PM
  #3298
teamgp's Avatar
How about fuscia?
teamgp is offline
Old 08-22-2005, 01:37 PM
  #3299
tboned_2002's Avatar
word
tboned_2002 is offline
Old 08-22-2005, 02:10 PM
  #3300
this is the most beautiful Xray T1 FK'05 i have ever seen...
Great job John thank you to make us dreaming...
miniwheels is offline
