Xray T1FK05
#3274
p.s. - first post.
#3275
Trader Rating: 102 (100%+)
ok...i've come out of hiding My First Post also on the threads....the hitmen will find me now..
but those pics are awesome....
nice wiring and well laid out washers through out the car.....great job...and what a cut job on the car body....
#3276
What is a good starting point in gearing a 48P FK04? I believe it has the standard pulleys. What gear ratio is good of stock indoor running on rubber tires? What about 19T indoor/rubber tire? The track is medium sized mix.
Do xrays use the same size shock springs as AE?
#3277
the ratio for a fk04 is 1.77 and your gearing depend on whats kind of motor you running and sized of the track! me for my track:
Monster Pro i have a roll out of 23-24
P2K2 is about 27-28
and you will heard if a motor is too overgeared and under geared!! if your motor will scream like a fool and you are ate the midlle of the straigth is overgeared !! what you want is to hear your motor is at his limit at the 3/4 of the straigth or at the end depend on how long his the straigth!! and the Monster motor is good for long tracl it has more RPM and the p2k2 is good for some tigth track lot of torque!! but i think they are both very good motor!!
The spring from associated fits perfect on the xray!! they are litle bit short than the xray spring so you will need to play whit the ride height
P2K2 is about 27-28
#3278
Can you get 64'P gears for the FK'05.
#3279
#3280
What would be a good price for a used FK05 in good shape ?
I don't have alot of info on the car.
I know it has two bodies.(STRATUS 3.0 and MAZDA 6)
Dual moter cooling fans
2mm chassis
I also know the car was always ran in ether 19 turn or Mod classes so it probaly has more hop ups than I listed.What would be a good $$$$$
What would be some good questions to ask the owner ?
What are the hot hop ups for this t\c ?
I am new to this hobby so any help would be awesome............
2mm chassis
#3281
P2K2 is about 27-28
P2K2 is about 27-28
How much shorter are the AE springs? Roughly what pinion/spur get you the 23-24 rollout with the monster stock?
#3283
Thanks for the info.
#3285
this is a roll out of 23 for the monster whit rubber!! with foam you need to calculate the roll out everyrun because yoour tire diameter is shorter because the foam tire is used!
spur gear pinion
128 27
108 23
93 20
Later!!
spur gear pinion
128 27
108 23
93 20
Later!!
