Like Tree1Likes
Xray T1FK05
Old 08-09-2005, 04:28 PM
  #3136
protc3's Avatar
hey guys,
i just started putting my car back together after anodize.what do you think?
protc3 is offline
Old 08-09-2005, 05:47 PM
  #3137
rdub202's Avatar
Trader Rating: 19 (100%+)
i think im extremely jealous
rdub202 is offline
Old 08-09-2005, 06:48 PM
  #3138
howard hudson's Avatar
Originally Posted by protc3
hey guys,
JASON WITH THE BLING BLING !!!!!!
howard hudson is offline
Old 08-09-2005, 06:59 PM
  #3139
John Fontaine's Avatar
Jas - Looks good.
John Fontaine is offline
Old 08-09-2005, 07:15 PM
  #3140
r0adrunn3r's Avatar
Do you want a set of RED TRF shocks to go with that?
hey guys,
r0adrunn3r is offline
Old 08-09-2005, 07:55 PM
  #3141
wo...very nice ar!!!!
is that difficult to anodize?
i want them in black or blue.....heehee...
tsuiyuen is offline
Old 08-09-2005, 09:49 PM
  #3142
Michael.H's Avatar
Originally Posted by work
Try using speedmind spurs. I havent replaced mine after 2 races and a couple of practice sessions, thats in stock i wouldnt know about mod. Plus very minimal signs of wear
Thanks for the help.
Michael.H is offline
Old 08-09-2005, 09:53 PM
  #3143
Michael.H's Avatar
Originally Posted by TraceRacing
The kit spurs are a load of poo. Get ones from RW and the problem will go away. Don't forget to replace the supplied motor screws with some proper 3mm ones.
Thanks also for the help.
Old 08-09-2005, 09:59 PM
  #3144
Michael.H's Avatar
hey guys,
The car looks really good, good job
I want a red xray.
Old 08-09-2005, 10:01 PM
  #3145
Roger's Avatar
That red is sweeet. I'd like to do that to my car, but i'd like to do all black anodizing.
Roger is offline
Old 08-10-2005, 07:04 AM
  #3146
teamgp's Avatar
Originally Posted by vtl1180ny
I should tell you the price of houses up here then.... If I could talk my ex wife into moving I'd be back down south in a heartbeat....
How well is the spektrum working in the car with the antenna cut down??? I'd like to trim mine but I'm a little concerned about running inside with all the flourescents....
You don't have to tell me the prices up there. Up until last December, I travelled a lot on business and I've seen the prices.
Without any exageration, I can honestly say that I haven't had one glitch since I bought the used M8 with a fairly new spektrum setup. I've ran it at our indoor carpet track, two outdoor parking lot asphalt tracks and in front of my house where all of our electrical wiring is underground and it has worked flawlessly. "Glitching" has almost been wiped from my vocabulary.
Jason,
How much material does the anodizing add to each surface area? Is the difference in the top deck height measureable?
teamgp is offline
Old 08-10-2005, 08:51 AM
  #3147
dado11g's Avatar
anodizing adds pretty much no material, this is b/c it is just corroding and not the adding of material. anodizing is controlled corrosion on the outer layer of the aluminum.
dado11g is offline
Old 08-10-2005, 08:56 AM
  #3148
dado11g's Avatar
i have a question now... i havent driven my xray since the winter and i forgot what pinion to use on a monster stock motor with a 112T spur gear. can anyone enlighten me?
also, how much better does the bmi chassis feel on the car? i had a bmi for my fk04 but not for my 05 (yet )
thanks
marshal v.
dado11g is offline
Old 08-10-2005, 09:09 AM
  #3149
lbckevin's Avatar
Trader Rating: 107 (99%+)
Dado,
I run a 26 on a tight track and a 27 tooth pinion on a larger track with the 112 spur.
lbckevin is offline
Old 08-10-2005, 09:10 AM
  #3150
dado11g's Avatar
thanks, i appreciate it
dado11g is offline
