Like Tree1Likes
Xray T1FK05
Old 07-29-2005, 06:18 PM
  #3061
teamgp's Avatar
Originally Posted by L.Fairtrace
no xray 30 wt is about the same as 50-55 wt ae oil.
Keep in mind that closing one hole with Xray oil is like closing 1 1/2 holes with AE oil. In other words, if two holes are closed on a shock with 30wt xray oil, and you want to build a shock with the same dampening but with 50wt AE oil, you would close three holes.
teamgp is offline
Old 07-29-2005, 07:59 PM
  #3062
No.... with 2 hole open in both shocks 30wt xray is equal to 50wt ae oil and both would be the same. If you used 30wt xray and 30 wt ae then you would use 3 hole pistons in the xray shock and 2 hole pistons in the ae shock to be the same. All that being said they would feel somewhat the same but the pack would be different. Changing oil or pistons you can get the same dampening but the pack is different if you use thin oil with less hole than if you used thick oil with more holes the dampening is around the same but pack does change. Hope that was explained so all could understand.
DJG24 is offline
Old 07-30-2005, 01:31 AM
  #3063
Sleighty's Avatar
Originally Posted by raving-monkey
even if they were recalled for destroying comms..his comm was fine so i doubt it was that.
Well im going to try another ESC as the one thats on my car smelt quite bad. It has that burnt smell of when you have blown it up. Yet it still runs fine. Perhaps i have blown some resistors or something and now the motors are getting too much current? Is this possible?
Sleighty is offline
Old 07-30-2005, 01:30 PM
  #3064
Scrad's Avatar
Trader Rating: 16 (100%+)
Does anyone have a wide top deck they wanna sell? I know some people have bought BMI chassis and don't need their old stuff.
Scrad is offline
Old 07-31-2005, 10:38 AM
  #3065
lbckevin's Avatar
Trader Rating: 106 (99%+)
Xray's kicked butt and won 19t and second in expert stock class at the Hitec Challenge race this year. Another vote of cinfidence for all xray fk05 owners.
lbckevin is offline
Old 08-01-2005, 02:05 PM
  #3066
Midnight's Avatar
Trader Rating: 87 (100%+)
I was running two holes all the way around, with 50 losi oil. I finally got my new tamiya shocks, could anyone tell me what would be compariable to my old xray shocks.
By the way, I didnt need any extra stuff to mount the shocks, I had to use some spare nuts to mount the ball studs on the shock tower, but everything else mounted right up, I also had to use the short lower shock mount instead of the long.
Midnight is offline
Old 08-02-2005, 01:29 PM
  #3067
HarshGuy's Avatar
Originally Posted by Formula1fan
I have new ones that xray sent me, should I get the expensive ones.
You installed the new ones they sent?? ...those should be fine, I ran those for a while no problem, although I have since upgraded all my thurst bearings to the Axiom ones.
HarshGuy is offline
Old 08-02-2005, 07:18 PM
  #3068
Bob Nilsen's Avatar
Default Fan install
Hey All,
Here are some pictures of my recent fan installation. It's worked out pretty well, and now the motor is runnin' much cooler (about 20 degrees).
more at:
http://www.glasselevator.net/bob/?q=node/223
Hope it helps somebody if they wanna try it for themselves.
Bob
Bob Nilsen is offline
Old 08-02-2005, 07:21 PM
  #3069
edseb's Avatar
Thought about that configuration, but I don't like the an working against the natural air flow with it pointing backwards.
edseb is offline
Old 08-02-2005, 07:22 PM
  #3070
edseb's Avatar
Originally Posted by lbckevin
Xray's kicked butt and won 19t and expert stock class at the Hitec Challenge race this year. Another vote of cinfidence for all xray fk05 owners.
Xrays are super good and I love mine, but Jason won Expert stock with his Corally RDX.
edseb is offline
Old 08-02-2005, 10:31 PM
  #3071
lbckevin's Avatar
Thats right Carl, I forgot my bad.
lbckevin is offline
Old 08-02-2005, 11:23 PM
  #3072
crACkeD ChaSsiS's Avatar
Default xray
Bon Nilsen- Hey man this is Steven Alexander(erkel), i raced with you in stock sedan Sunday. Is the set-up really different from a 04 to 05t1fk? Because Sunday was my first day running my Xray04 t1fk, and i think that was my worst race day ever as you can see i only completed one race because i didnt like how the car was handling. Im going to reset it up an try an work from there. Also did you hook your fan into your battery slot on your receiver?
Steven
crACkeD ChaSsiS is offline
Old 08-03-2005, 05:11 AM
  #3073
ChrisP's Avatar
Setup is different between the two cars...
Setup is all about controling weight transfer and the weight distribution of the FK05 is quite a bit different than the FK04....as such it requires a different setup...
check out the setups section on the teamxray.com forum for help with FK04 setups
ChrisP is offline
Old 08-03-2005, 10:47 AM
  #3074
Ztrezz's Avatar
And what about oil from Team Orion. Is this oil the same as Xray or AE ?
Ztrezz is offline
Old 08-03-2005, 01:43 PM
  #3075
vtl1180ny's Avatar
Finally got mine together, can someone enlighten me on bag 0014? It's got a lot of screws and a plastic L shaped thingy....
vtl1180ny is offline
