Like Tree1Likes
Xray T1FK05
Old 07-28-2005, 12:49 PM
  #3046
John_S's Avatar
make sure u dont have the pinion in to far as its quite easy to do on this car . The pinion may be touching the base of your can where the armature comes out and rubbing heating up the can and probly the armature. Check the bottom of your can for scruff marks
John_S is offline
Old 07-28-2005, 02:19 PM
  #3047
Sleighty's Avatar
well, ive just stripped the motors down and quite simply the windings on arm have burnt up. Well one of the sets of 3 have burnt on each motor.
The magnets are coated in the burnt epoxy i presume.
I cant see what the problem could be besides the ESC?
But could it be a ESC problem? What could go wrong with an ESC that would cause it to overload the motor?
Any ideas?
p.s. I checked my pinion position and the cans of the motors and there is no worn cans suggesting the pinion being too close to the can.
Sleighty is offline
Old 07-28-2005, 02:59 PM
  #3048
Is there any evidence of "scratches" on the magnet face? You could have picked something up and jammed the armature for a second...
TraceRacing is offline
Old 07-28-2005, 04:39 PM
  #3049
Jammin'Trey's Avatar
hey guys i am looking at buying a fk05 what are the pros and cons?? i used to have a raycer and loved it... then offroad came around and had to sell it
Thank you all for your time
Jammin'Trey is offline
Old 07-28-2005, 05:06 PM
  #3050
Scho's Avatar
3 Motors dave
Scho is offline
Old 07-28-2005, 05:08 PM
  #3051
Scho's Avatar
Any ideas?
Paul i reakon your just a throttle jammer
Scho is offline
Old 07-29-2005, 04:36 AM
  #3052
Formula1fan's Avatar
Getting back to my FK05 after a brief experiment with a PRO4 (man what a nightmare). I just changed to Acer 2.4mm diff balls and I can’t get the diffs to stay smooth. They are perfect for approx three runs and then they feel nasty like a TC3 diff. Any suggestions?
Formula1fan is offline
Old 07-29-2005, 05:11 AM
  #3053
S-T-R-l-K-E-R's Avatar
your thrust bearings are busted. i suggest you get a new set o' trust bearings
S-T-R-l-K-E-R is offline
Old 07-29-2005, 09:58 AM
  #3054
John_S's Avatar
hey sleighty are you running a nosram dominater (non evo version) because they have been recalled for anihalating comms after only 1 run
John_S is offline
Old 07-29-2005, 10:46 AM
  #3055
I have new ones that xray sent me, should I get the expensive ones.
Old 07-29-2005, 02:04 PM
  #3056
pheyhoe's Avatar
its an LRP quantum 1 which is the same right?
pheyhoe is offline
Old 07-29-2005, 02:48 PM
  #3057
Scho's Avatar
Its not a problem, i ran one for ages aa while ago
Scho is offline
Old 07-29-2005, 03:31 PM
  #3058
raving-monkey's Avatar
even if they were recalled for destroying comms..his comm was fine so i doubt it was that.
raving-monkey is offline
Old 07-29-2005, 03:51 PM
  #3059
Default shock oil
Is Xray 30wt the same as losi or ae 30wt
alien too is offline
Old 07-29-2005, 04:11 PM
  #3060
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
no xray 30 wt is about the same as 50-55 wt ae oil.
L.Fairtrace is offline
