Xray T1FK05
#3016
Originally Posted by John_S
hi guys i was wondering if there are any direct fit spurs that fit the 05 i.e robinson racing or kimbrough or rw
rw - i believe the spur i'm holding in my hand is an rw. it is 114t 64p and feels like it was machined instead of molded (all sharp edges). again, i'm not sure if they have different models, but this particular spur is setup with 8 'inner' holes, meaning the 3-hole fk05 mount does not fit. the spur itself has a 114 cut into the side with what looks like a felt pen to highlight the numbers.
prs - read nothing but good things about these. could not find anyone carrying them (local, stormer, tower, etc). went to their web site and ordered a couple last night. make sure to get the 'pro lite touring' version, as these have the 6-hole configuration that fits the fk05. i do not know if their other product lines do.
last but not least, searching through this thread, it looks like most people are putting the biggest spur they can on the car. i think the magic number is 116 in 64P pitch and 87 in 48P.
hope this helps
also, regarding prs. i have checked their site a few times in the past year, they always are out of stock on several popular sizes of gears and do not offer 'bulk assortments' for those of us looking for it all. anyone that knows someone at prs might want to reccommend fixing this.
#3017
rw now offers a 6 hole spur gear that fits perfect on the fk05 which i have on my ride right now and have had no problems running it. i have also ran a 7x1 with this spur gear not one lick of trouble. i run the 118t 64p. i have also ran the prs gear with the same result as the rw gear no problems just that prs is more expensive.
#3018
I have the PRS 120 tooth but I run the 3.0 carpet chassis and I beveled the chassis so the spur doesn't hit. It's just a tiny, tiny bit.
#3019
im running a 128spur 64pitch.
#3020
#3022
Originally Posted by gee-dub
howard, your post got me thinking. a 128 on carpet might be a factory team secret. think of the extra traction you'd get with the spur chewing into the carpet for traction ~
#3023
L8er bros
#3026
Originally Posted by 1armed1
Do you have to do any mods to fit the 120 spur to the 05? If any, what mods are required?
Also where can I get this spur from?
#3027
na man no mods, cant remember were the spur came from. i run this on indoor carpet.
#3028
If you don't run the 3.0 carpet chassis the 120 sticks out the bottom a little. With the carpet chassis it just sits flush with the bottom, but I did file the chassis a little under the spur just like you would battery slots. I bought my PRS gears from a local hobby shop. I think KTHOBBIES.COM has them in stock for online purchase though.
#3029
i have an 87 on at the moment because i got a stone stock under my kit spur when coming out of a slow hairpin and went to accelerate and the pinion moved but the spur didnt
. And i need an 84 on to get proper gearing for 19t because the biggest pinoin i can safely get on with the correct mesh is a 26 giving me an overall of 5.69 whereas id like to be running 5.28 which is a 28 pinion but it doesnt fit. So ima needin a smaller spur but have already scrood 2 of the 84's
#3030
hi,
i use a kimbrough spur for my FK'05, the width is not the same
use abrasive paper to decrease the width
http://img110.imageshack.us/img110/3...3fleche7xg.jpg
http://img110.imageshack.us/img110/8...hecoupe7nt.jpg
sorry for my english
