Like Tree1Likes
Xray T1FK05
Old 06-29-2005, 01:17 PM
  #2821
yes.. I'm running a 120
do you have the 3.0 chassis or 2.5?
Justin Zorc is offline
Old 06-30-2005, 02:25 AM
  #2822
Roger's Avatar
Harsh: I used your set-up last night on a VHT sprayed track and the car was dizialed !!!!! Thanks. I kept Lex and E.J. from passing me during the second qualifer in 19T
Roger is offline
Old 06-30-2005, 07:08 AM
  #2823
HarshGuy's Avatar
Saweet ...yea it works great, you just have to DRIVE the car the whole time, it ain't an "autocruise" kind of setup ...I was driving 19T like ass at Ripon last weekend and it showed, setup worked well went were I wanted it to, I just wanted it to go up on berm after berm after berm after berm
HarshGuy is offline
Old 06-30-2005, 07:24 AM
  #2824
jaysimpson's Avatar
Harshguy: Would you mind sharing the setup? We run on VHT here as well and I would be interested in trying it out.
jaysimpson is offline
Old 06-30-2005, 07:52 AM
  #2825
jdm19turn's Avatar
yea harshguy i would like to try your 19t setup as well would you please post it on this thread
jdm19turn is offline
Old 06-30-2005, 07:59 AM
  #2826
HarshGuy's Avatar
It's at www.gearchart.com ...go to the "Electric Setups --> On Road Setups" ...look for my name under driver (Arroyo, Javier) , it's the 2 "Points series" setups one is for stock one is fo 19T ...I actually am running a little different now, but that's what Roger downloaded ...and "word of caution" ..it's very "twictchy/sensitive" whatever you want to call it, you have to drive it and have good throttle control in, during and out of corners.
HarshGuy is offline
Old 06-30-2005, 08:06 AM
  #2827
rayhuang's Avatar
Default sway bar help
Hey guys,
I was helping my buddy install sway bars on his FK05. I need some help.
They didnt seem to have much effect untill the arms were almost fully raised. We of course shortened the lever arm, but by the time we got the sway bar to react quicker-the sway bar mounts hit the driveshafts.
Any tips on how to make the sway bars (Front and rear) take effect with less suspension travel?
Thanks in advance,
Ray
rayhuang is offline
Old 06-30-2005, 08:33 AM
  #2828
Ray, you need to use the outer hole on the arm. Mine began to raise the opposite arm as soon as I lifted one side.
brianrice is offline
Old 06-30-2005, 08:34 AM
  #2829
rayhuang's Avatar
Wow-as simple as that? What sre you-some kind of Touring specialist??
rayhuang is offline
Old 06-30-2005, 08:39 AM
  #2830
I wish!
Did Jody have the ball cups mounted on the inner hole?
Old 06-30-2005, 08:40 AM
  #2831
V12
V12's Avatar
Someone knows how much lower the front foam shock tower is in compare to the stock one? The Xray website doesn´t say anything on this.
V12 is offline
Old 06-30-2005, 08:43 AM
  #2832
rayhuang's Avatar
I wish!
I dont recall-I thought he did-I'll ask him today.
rayhuang is offline
Old 06-30-2005, 09:07 AM
  #2833
lbckevin's Avatar
Trader Rating: 104 (99%+)
hey guys,
I just got the new fk05 today and I am looking for a stock motor setup for socal raceway in CA. Its a tight , med size track on asphalt (black top). Let me know what I can do.
Kevin
lbckevin is offline
Old 06-30-2005, 10:31 AM
  #2834
Roger's Avatar
Thats great Jav. The 15th is still on. How's the weather been doing up there ?
Roger is offline
Old 06-30-2005, 10:56 AM
  #2835
HarshGuy's Avatar
Thats great Jav. The 15th is still on. I'll be bringing Hicks, Broldan, Marquez, and myself. All xrays of course. How's the weather been doing up there ?
kewl ...yea at SWR I've been "floppin" back and forthe between a oneway and a locked oneway (not a spool) ...and sometimes adding a mm spacer for rear toe ...we can't run VHT at the track, between the police station, fairgrounds, SPCA, and child day care they get "wierd" about stuff like that on the ground (we also get "spanked" if we spray motor spray on the ground) ..I'm gonna be testing Aaron's "secret sticky sauce" tomorrow and see how that works out.
Weather's been getting progresively and exponentially hot, I'd expect low 100's by the 15th.
HarshGuy is offline
