Xray T1FK05
#2716
Thanks guys. Think I'm going to wait to attack it when i really need to, like when i get the 3mm chassis. Its going to be hard to get that one out i know the other ones that i took out you when you turn it you hear a crack then it comes lose like there in there good. wish there was a quick fix for that. I will be getting a 2mm wrench
now..
#2717
I have had success superglue-ing the allen driver into the stripped screw head. After a couple times with stripped screw heads I learned to just not overtighten those screws.
#2718
I changed out all the silver allen screws to hpi screws. The silver screws for some reason are too soft even for my new Hudy 2.0mm allen wrench.
#2719
Originally Posted by teamgp
I agree. Although I wouldn't call others who disagree stupid.
#2720
Originally Posted by kewdawg
He didn't say THEY were stupid - he said, he thought doing that tuning option was stupid. BIG difference. Especially, with the "sensitivity" levels on this thread.
And I am sensitive! Sensitive enough to ask Tito for a tissue...
#2721
Now I thought the rule was "stupid is, as stupid does." So if I do something stupid, then I'm stupid, though maybe only temporarily so. <== like this
#2722
Originally Posted by L.Fairtrace
I had my car pretty dialed on high bite asphalt last weekend. I was using the 2.5mm chassis, wide topdeck with all 4 posts. I tried with no posts and it was unpredictable on power in the turns. So I tried all 4 and it was much, much better and way more consistent.
I also agree with Mdoc. You can shave .2 off each lap with all the tuning parts but if you have a 4 second wreck it was all pointless.
#2723
#2724
Originally Posted by MartynD
Whats a set of bulkheads cost? Think they are around $180 cdn. Removing screws from the bulkhead is STUPID if you have a tendency to hit immovable objects from time to time. I've seen one set of bent bulkheads caused by following the Tip outlined on the XRay website, and then during normal racing coming into contact with something. The driver that did it, is one of the top drivers in the GTA (Toronto area)
Find other ways to add more flex.....
This is done by TEAM members to give them an advantage.
You do this at your own risk. Team members may break whatever they want, it doesn't cost them anything. However, if the mod gives them an edge, they don't care.
On the other hand, if they did not release this information, we would be bitching about how they do not release their setups.
Xray is damned if they do and damned if they don't.
#2725
Originally Posted by punkboy
all i wanna know is, Whos Tito?
#2726
any shops got the 2.0 chassis in stock?
#2728
Originally Posted by howard hudson
I think he is the brother of some loser that just got off the hook..
#2729
Are you saying YOUR judicial system doesn't work?YES Or, are you easily influenced by the media?NO ! I believe the phrase is: Innocent until... YOU HAVE ENOUGH MONEY TO BUY THE JURY, right? Let's just keep it r/c and leave the VERY RICH "loser" to himself. I'm sure he wouldn't have to budget his r/c racing, like so many of us do.
