Like Tree1Likes
Xray T1FK05
Old 06-03-2005, 05:34 PM
  #2566
kyle "hitawall"'s Avatar
Originally Posted by TryHard
Actually from what he says, it sounds like he's keeping the pin flat. In that case, your lowering the front roll centre, and hence more grip.
Also, if you just lower the front pin mount (so the front of the arm is lower than the rear) you get pro-dive, not anti (BTW, Kick-up IS anti-dive). This gives more initial steering (something I use with good effect when running a spool in my 415) on corner entry, but also reduces the castor angle. Of course the roll centre also changes....
I'm not sure about the link too... I've always found a shorter link to give more grip through the turns...
Regards
Ed
so then to get less initial steering and more steering through the center and off the corner i raise the front pin mount. also what does pro-squat and anti-squat do.
kyle "hitawall" is offline
Old 06-03-2005, 05:35 PM
  #2567
stinkypop's Avatar
Originally Posted by HarshGuy
Yep ...I'm running this on mine and that is the effect it has.
sorry my bad.
lowering the front pin will reduce caster therefore increase steering.
stinkypop is offline
Old 06-03-2005, 07:55 PM
  #2568
centax error!'s Avatar
Originally Posted by stinkypop
sorry my bad.
which part of the turn? I assume you gain initial steering but loose some on the middle part because you will loose some camber as you turn the wheels correct me if I'm wrong
A:your creating anti dive= reduced off power steering
:short link= Less roll= flater through corners/ less cornering grip
I meant lower the hingepin ( flat). If the car is pushing on the middle turn, can I use this tuning to the front ( Front RClower than Rear RC) to increase mid steering.
shorter link=less roll- means quick direction changes? is this a good tuning ( shorter link front and rear) if the layout has lots of chicanes and succesive left and right turns?
shorter link on front= less cornering grip on front-means that I can use this tuning if the front suddenly hooks during intial turn? I had this problem before and what I did was to stiffen the front and it worked but I guess I lost some steering on the rest part of the turn somewhat
B:kickup= less off power st/ more on power st and generally more stable
I was running kick up last night with a blue springs up front and yellow on rear and the car was loose coming in turns. Change to white springs on the rear ( thought yellow was toosoft ) but still loose. Changed to dark blue springs on the front and it got better. Then added sway bar to the front on next run and the rear didn't break traction anymore. I can't really understand what I did but it worked that night I think I reduced some some weight transfer to the front but then again it felt better with the sway bar so I reduced chassis roll also. I wonder If could have changed either one only and get rid of the problem totally but I did not have enough time to go back bec it was during a race. I think it's a good idea to make only one change at a time so you will understand the effect and learn from it
:long link= more roll/ more cornering grip
My car felt it has more steering when I had the shorter link. I am using the middle hole now to be safe and mess with it until I figured it out Maybe someone can shed more light between a shorter and a longer link
to get back the off power steering you lost, reducing droop in the car(more on the gauge) , but if you are running soft springs chances are it will be too soft and the chassis may scrape due to the extra roll from the camber link change.
hope this helps
Matt
What does it mean by fast speed steering and slow speed steering? fast speed= off power entry coming from a straight?, slow speed steering= off power steering on the infield?
Pardon for lots of newbie question but I'm eager to learn how to set up my 05 right
Thanks in advance.
CE-X
centax error! is offline
Old 06-03-2005, 08:38 PM
  #2569
Regards
Ed
Ed, your right I meant the front hinge pin flat.
I haven't tried pro dive before but might as well try it though. I'm used to oneways and when I made the switch to diff it felt like I'm missing some of the off power steering on entry. Our track is bumpy and if I have pro dive do I need to stiffen up the front or reduced rear droop so that the front end of the chassis will not scrape to the ground? I'm worried that by reducing rear droop will again take out some steering off power on entry. Also, to compensate for the lost caster ( due to pro dive) do I need to change caster blocks form 3to 4.5 degrees to keep mid corner steering if I was already happy with it when I had a zero kickup?
Thanks in advance.
CE
Old 06-04-2005, 01:42 PM
  #2570
Formula1fan's Avatar
I an running the multi diff locked (spool) man that thing chews threw the dog bone blades. Has anyone else had this problem, and come up with a fix.
Formula1fan is offline
Old 06-04-2005, 01:43 PM
  #2571
kidDynomite's Avatar
Thanks in advance.CE
Pro-dive works great with a one-way. Keep the rears in the middle holes. I still get lots of steering with the 3* blocks, but the 4.5's do a better job. Your front end won't scrape the ground. Just try it with your current setup to feel the difference, then make changes from there. It's hard to explain, but the front end always felt planted or running flat. I've even tried it with a one-way and foams and if felt like I was running a diff, but more free with strong pull out of the corners. It's definitely worth experimenting with.
kidDynomite is offline
Old 06-04-2005, 01:49 PM
  #2572
The spool is working 100% of the race. There's no give at any point so the only fix is a bunch of spare blades in the tackle box.
Old 06-04-2005, 02:13 PM
  #2573
TryHard's Avatar
I'm not sure how it works on the Xrays, but on my 415, if i place 1mm of shims under the rear block on the front, it equates to just over 1deg reduction in castor, ie I go from 4 to 3deg. Personally I just leave it with the reduced castor.
I wouldn't worry too much about masses of changes to the chassis, so don't bother with spring change etc, it's more of a fine tune (but still has a good effect) than say changing springs.
Just make sure you reset your FRONT droop if you do it though, the new arm angle will mean your droop screws are in a different place
HiH
Ed
TryHard is offline
Old 06-04-2005, 02:40 PM
  #2574
protc3's Avatar
hey guys,
i have my final prototype finished for the fk05.i moved the batteries on the car to eliminate some of the weight transfer to the front going into the corners.i always felt the car was loose in the rear with standard setups and this corrected it.i moved the servo forward some and also made the motor mount adjustable from front to rear so you can adjust gear mesh in a hurry with your batteries in the car.i also cut a .025 deep pocket under the batteries for your tape to lay in so it doesnt rub the carpet or asphalt.i made it possible to run my included battery strap,xray's battery strap or use tape.the cell slots will fit 3300,3600,and 3700 cells.i also cut out pockets under the diffs to make diff adjustments with the body on.heres some pics.let me know what you think.
Attached Thumbnails Xray T1FK05-adjustable-motor-mount-fk05.jpg   Xray T1FK05-new-fko5.jpg   Xray T1FK05-fk05-tape-pocket.jpg   Xray T1FK05-fk05-front-tower.jpg   Xray T1FK05-rear-tower-fk05.jpg
protc3 is offline
Old 06-04-2005, 03:04 PM
  #2575
Charles Godwin's Avatar
My fk05
Charles Godwin is offline
Old 06-04-2005, 03:26 PM
  #2576
mike ivy's Avatar
Trader Rating: 50 (100%+)
When Is the chassis going to be available and also what is the thickness of the chassis
mike ivy is offline
Old 06-04-2005, 03:58 PM
  #2577
stormperson's Avatar
Jason- Just curious, in which direction did you move the batteries? And also how does the servo movement affect the weight distrabution?
And also compared to the stock 2.5mm chassis how much does the chassis weigh?
Thanks!
stormperson is offline
Old 06-04-2005, 05:36 PM
  #2578
protc3's Avatar
the chassis is quite a bit lighter than the stock chassis.it is also 2.5mm but is made from a high modulous carbon fiber for carpet and quasi isotropic for asphalt.moving the servo forward added some weight over the left front tire for a better balance and also adds a little more room for electronics.batteries were moved forward just enough for even weight transfer from front to rear,rear to front and left to right.i found that with the batteries as far back as they are stock,it seems to transfer too much weight forward entering a corner and whipping the rear end anound and also creating excess roll in the front end.making these changes allowed me to use my standard setups and also makes the car react alot better to setup changes.i will take the actual weight of the car with electronics as soon as possible.im still having fun running it
protc3 is offline
Old 06-04-2005, 06:53 PM
  #2579
Well I am chewing up blades running the mutli-diff as a one-way. Though I run the car alot (2 nights and 1 full day a week) I have been replacing blades every 2 weeks since I went from the ball diff to the multi-diff. I run 19T and stock.
MartynD is offline
Old 06-04-2005, 07:27 PM
  #2580
Default blades
I'm running 19t and Mod.. After 2 runs with a 8turn It looked like i need to changed them. Its alittle bit better with a 19T. They need to start sell them in bulk 25 pack....
John Q is offline
