Like Tree1Likes
Xray T1FK05
Old 06-03-2005, 04:56 AM
  #2551
acutts's Avatar
Originally Posted by Formula1fan
I am going to pick some up also, but the manual says they are 2.4mm.
Closest that seem to be available are 2.5mm ... u reckon these be okay????
acutts is offline
Old 06-03-2005, 05:11 AM
  #2552
TryHard's Avatar
Originally Posted by stinkypop
A:your creating anti dive= reduced off power steering
:short link= Less roll= flater through corners/ less cornering grip
Actually from what he says, it sounds like he's keeping the pin flat. In that case, your lowering the front roll centre, and hence more grip.
Also, if you just lower the front pin mount (so the front of the arm is lower than the rear) you get pro-dive, not anti (BTW, Kick-up IS anti-dive). This gives more initial steering (something I use with good effect when running a spool in my 415) on corner entry, but also reduces the castor angle. Of course the roll centre also changes....
I'm not sure about the link too... I've always found a shorter link to give more grip through the turns...
Regards
Ed
TryHard is online now
Old 06-03-2005, 05:24 AM
  #2553
Formula1fan's Avatar
Try acer they have 2.4: http://www.goemerchant7.com/index.cg...Number=nitride
Formula1fan is offline
Old 06-03-2005, 06:15 AM
  #2554
HarshGuy's Avatar
Originally Posted by TryHard
Also, if you just lower the front pin mount (so the arm slopes downward) you get pro-dive, not anti. This gives more initial steering
Yep ...I'm running this on mine and that is the effect it has.
HarshGuy is offline
Old 06-03-2005, 06:36 AM
  #2555
You can get 2.4mm from HPI
MartynD is offline
Old 06-03-2005, 07:19 AM
  #2556
acutts's Avatar
I'll have a look ... I worked out that 2.4 is almost 3/32 ... 2.3812.... I wonder if these balls are 2.4 I am going to check them on a micrometer tonight before I purchase as all the places in UK have either 2.5 or 3/32 ...
acutts is offline
Old 06-03-2005, 09:08 AM
  #2557
Qwiglee's Avatar
I got my diff balls from Acer, they have ceramic, carbide and HCCA (ultralite) and they offer all popular sizes including 2.4mm.
http://www.acerracing.com/balls.html
Qwiglee is offline
Old 06-03-2005, 09:30 AM
  #2558
I found out the reason why my belt was clicking...STUPID ME!! My rear diff height adjuster were off bt left and right! DUH!!!! Hehe.....
G
loosenut is offline
Old 06-03-2005, 10:00 AM
  #2559
I run 2.4mm Ceramic balls, the diff is smoooooooth... until you hold one wheel and the spur. Then its sticky. I think the diff rings are actually sliding on the diff halves. Next time I take the diff apart I will try and resolve it. It has been suggested that I glue the rings to the halves, but I am reluctant to do that.
I have yet to find another 05 with ceramics to find out for sure if thats what causes it. Every one else I know running the car is using the kit balls and there diffs work fine (tho not as smooooth +)
MartynD is offline
Old 06-03-2005, 11:56 AM
  #2560
big_G's Avatar
Your right about 3/32 - but check out Microtech - they have 2.4mm ceramic balls in sets of 12 for the Pro4.
They will do
big_G is offline
Old 06-03-2005, 12:16 PM
  #2561
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Originally Posted by HRCRACER123
And with that clicking sound make sure you put the differential height adjustments in correctly. Pretty much just look at the diff and see if its straight. If its not there is your problem.
Hey Loosenut I guessed right what do I win.
HRCRACER123 is offline
Old 06-03-2005, 12:40 PM
  #2562
Trader Rating: 14 (100%+)
Martyn:
Hi,
I still have the same problem as you do with the diffs. I am going to pin a diff (like you do in 1/12th scale) to see if it helps. I also went to 3/32 balls and made the differance up in the rings (ground them down) this seemed to help a little.
are you going to the Vegas race???
TimXLB is offline
Old 06-03-2005, 12:45 PM
  #2563
kidDynomite's Avatar
On MyTSN, their was an article about polishing the diff rings for Serpent cars. Really helps make the ceramic balls glide. This is what I did to resolve the stickiness. Even smoother now.
kidDynomite is offline
Old 06-03-2005, 12:50 PM
  #2564
Tim..
As 3/32 is smaller than 2.4mm ... grinding down the rings seems the wrong thing to do... but I could be wrong...
I may just go back to carbide balls... we'll see, the diff feels great and I haven't had any issues (that I can tell)
No Vegas for me...
MartynD is offline
Old 06-03-2005, 01:14 PM
  #2565
Martyn:
Hi,
I might have used a size larger than 3/32 as they came from my son's shop . they were marked 3/32nd and were larger than 3mm I only took a light pass with a blanchard grinder. I will let you know how the pinned diff works out.
sorry you can't make it to Vegas.
hopefully we'll see you at Cleveland.
TimXLB is offline
