Xray T1FK05
#2507
Originally Posted by acutts
Under load at full lock I seem to get loads of chatter at the front wheel and can't find the problem??
I have turned the steering down so that it doesn't touch the c-hub at full lock but problem persists ... any ideas??
#2508
Originally Posted by MartynD
My guess... Is dogbone rubbing on the axle hub.
#2509
Are the dogbones bent at all? Also check for cracked C-hub, underneath where the screw goes through into the hub carrier.
#2510
Don't believe dogbones bent as I have never hit anything with it yet. But I will look at home tonight. The c-hub also can't be cracked as I am running alu ones.
Cheers
Cheers
#2511
are you running the alum. drive hubs or the spring steel? if you are running the alum. one replace them both with the spring steel ones and you problem will be fixed.
#2512
Never had this problem with the XRAY, in fact it has the smoothest transmition all around compared to any other car I've built so far (YOKOMO, ASSOC,TAMIYA, HPI).
A detailed picture might help a lot to identify what is causing the problem..
#2513
Any one interested in a "new in box" "factory sealed" Euro version T1FK 05' with multi-diff click on link below
http://www.rctech.net/forum/showthread.php?t=73871
#2514
#2515
I ran a front spool for the first time this weekend. I was wondering if the belt needs to be tightened when you do this. I never heard the belt slip when I had a front diff. I also had the diff pretty tight, since I was waiting on the multi diff to arrive. I also had the belt flip on me in one of the qualifiers.
I also need a drive ratio suggestion. I am running at a track with two long straights. I am running rubber tires, and epic roar stock motors. THANKS
#2516
i had the dame problem too what i did is i took the epic out of my cat and put any tuned monster in then i tightened the belt i space just to keepa little bit of tension, then put a 3mm clip in the back nothing up front and that should fix your problems just make sure to check camber and ride hieght again to be sure
hpipro321
hpipro321
#2517
Anybody know how much would be involved to change a Freedom of Choice to the new chassis ? is it possible or just not worth the cost?
#2518
It will be cheaper to buy a new kit than upgrading your FOC being there are very few comon parts with that car.
#2519
OK thanks, will probably stick with what I have now then, it still handles better than most other cars.
#2520
