Like Tree1Likes
Xray T1FK05
Old 05-20-2005, 11:29 AM
  #2371
Two different positions?
Can't see my car right now... but mine has one position not 2.... (unlike an older model XRay I saw recently...)
MartynD is offline
Old 05-20-2005, 12:04 PM
  #2372
V12
V12's Avatar
The plastic adapters for the bearings of the servosaver are excentric. So you can move the servosaver a little if you turn these adapters by 180°.
V12 is offline
Old 05-20-2005, 07:18 PM
  #2373
Tim Stamper's Avatar
Originally posted by V12
Anyone tried the two different positions for the servosaver? Canīt find any information on this.
I didn't because it looks like it would put the servo saver/post too close to the diff.
Tim
Tim Stamper is offline
Old 05-20-2005, 07:50 PM
  #2374
Roger's Avatar
I posted on May the 18th in regards to the thrust bearings. 2 days later ( May 20th ), I go to my mailbox and sure enough, they they were. Two copper thrust bearings from RC America .
Now that's what I call service
Roger is offline
Old 05-20-2005, 08:22 PM
  #2375
scoobydo's Avatar
Yeah, they did a great job of handling the whole thing.
Got mine right away as well.
scoobydo is offline
Old 05-21-2005, 07:16 AM
  #2376
Well... no sign of em in Canada yet... (RCA supplies Canada)
MartynD is offline
Old 05-21-2005, 12:26 PM
  #2377
Leini's Avatar
changing the servo saver position has the same effect as changing the steering link pos. but in finer steps.
Leini is offline
Old 05-21-2005, 02:30 PM
  #2378
acutts's Avatar
How in the heck do you get the snap ring out of the rear diff to replace the thrust bearing ... I have not got any pliers thin enough to get in the holes? Please someone help I need to fix this before I race the car tomorrow????
acutts is offline
Old 05-21-2005, 03:02 PM
  #2379
Michal101's Avatar
Originally posted by Michal101
I will racing my FK05 this weekend on fairly smooth asphalt with rubber tires and I was hoping somebody had a good setup to start off with.
Thanks, Mike
Anybody???
Michal101 is offline
Old 05-21-2005, 03:11 PM
  #2380
ALBERTO's Avatar
Trader Rating: 23 (96%+)
you need snap ring pliers or just bend it out and just replace it with a new one snap ring that is click here
ALBERTO is offline
Old 05-21-2005, 04:17 PM
  #2381
Eric Gebhard's Avatar
Anybody???
I would suggest going to Xray's web site and looking at some of the setups that have been posted there. Check out the setups posted by Gabe. I'm using his spool setup and it works pretty well.
Eric Gebhard is offline
Old 05-22-2005, 09:59 PM
  #2382
S-T-R-l-K-E-R's Avatar
just wondering if anyone has tried a front overdrive spool set-up. is it possible since the smaller spur is 2 teeth smaller. usually you only need 1 tooth smaller to achieve overdrive
S-T-R-l-K-E-R is offline
Old 05-22-2005, 10:35 PM
  #2383
You can find snap ring pliers that are small enough at McMaster Carr (www.mcmaster.com). Otherwise you can just take two body clips, insert them in the snap ring hose and squeeze the clips with some needle nose pliers.
Lano is offline
Old 05-23-2005, 06:00 AM
  #2384
Princess Auto carries a set of small snap ring pliers, $10 USD...
OOps.. bet there is no Princess Auto in the UK...
MartynD is offline
Old 05-23-2005, 06:16 AM
  #2385
HarshGuy's Avatar
Xray FK05 ...Tons 'o parts for sale
http://search.ebay.com/_W0QQsassZkalliea
HarshGuy is offline
