Old 05-18-2005, 07:29 PM   #2341
Send a message via AIM to micros_rock
Originally posted by kewdawg
Guys,
my rear diff becomes "knotchy" during running, then goes back to normal, 5 - 10 mins. after the run. I did, initially, have to rebuild the diff with new diff rings, balls and a new thrust bearing, of course , then this started happening.
Did you properly break-in the diff?
micros_rock is offline   Reply With Quote
Old 05-18-2005, 08:22 PM   #2342
Default Re: fk05
Originally posted by StartBuck
hey wanted to know if someone could tell me how long the shocks should be ? I was screwing the end of the shock on and didnt want to split the plastic end, I dont know how far to go?
Thanks Guys...
I just eyeballed it... I couldn't get the ends on as far as the manual suggested but I got it close. In the end I measured the shocks and got pairs matched up, so one pair may be half a mm longer than the other.
MartynD is offline   Reply With Quote
Old 05-18-2005, 08:26 PM   #2343
centax error!'s Avatar
and what's the right way to do it after rebuild?
centax error! is offline   Reply With Quote
Old 05-18-2005, 08:27 PM   #2344
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Originally posted by John Fontaine
I received my replacement axial bearings from RCAmerica on Monday. Bryan sent me an email reply which was very nice. Kuddo's to Xray for resolution to this problem.
JF
how were the thrusts I sent ya?
dgullickson is offline   Reply With Quote
Old 05-18-2005, 08:28 PM   #2345
Sounds like you need a rebuild .. The Diff lube is heating up when your running and getting thin, causing it to fell crunchy. Then as the lube cools down after the run it gets thinker making it feel normal...
StartBuck is offline   Reply With Quote
Old 05-18-2005, 08:29 PM   #2346
Default Re: Re: fk05
Thanks man.. How much thred should i see on the shaft ?
Old 05-18-2005, 08:29 PM   #2347
HarshGuy's Avatar
Default Re: Re: FK05 Stock Rubber Carpet Setup
Originally posted by BlackKat
Try getting ahold of Tom (Tboned2000) and ask him for his Hobbyworld Gilroy setup
It's here: http://www.gearchart.com/index.cfm?f....sheets&type=1
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-18-2005, 08:30 PM   #2348
Same way as the manual suggests...
Run it loose for a pack, and then tighten it a bit, then run some more and tighten and so on.
Old 05-18-2005, 08:33 PM   #2349
Default Re: Re: Re: fk05
(digs out the manual...) it says 1 mm I couldn't get them that far, but real close. if you can get it within 1-2mm you be fine, so long as you match them up in pairs.
Old 05-18-2005, 08:57 PM   #2350
howard hudson's Avatar
R/C Tech Charter Subscriber
Default spool
does anyone besides Xray make a spool ??? They have discontinued it since the multi diff has come out. Does team tammale make one ???
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 05-18-2005, 09:11 PM   #2351
Send a message via AIM to loosenut
I'm getting a fk05....
what spare parts do I need to have for 19T club racing? I've already got the axiom thrust bearings. I'll be racing on asphalt medium bite track. Thx.
Gary
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 05-18-2005, 09:21 PM   #2352
kewdawg's Avatar
Yes.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-18-2005, 09:23 PM   #2353
scoobydo's Avatar
Gary
I would just get a spool if you can find it, or youll have to shell out for the Multi Diff.
The light blue springs seem to be working for me on asphalt.
If you want to go over protective, get a rubberneck bumper and maybe some Alum chubs.
Maybe the Spring steel outdrives, but those would be last for me, get the other stuff first.
*EDIT*
oops.Sorry, I though you meant upgrades not spare parts.
scoobydo is offline   Reply With Quote
Old 05-18-2005, 09:25 PM   #2354
kewdawg's Avatar
Re-read my post. I did rebiuld it using the included Xray grease. I think something in the assembly is warping as the diff heats up during the run. I'm really not sure.
Quinn Moon
Old 05-18-2005, 09:49 PM   #2355
If you want to use the ackerman extension set be sure to stock some steering knuckles because they will break by almost every hit (the rubberneck front bumper helps a bit). One set of suspension arms is also a nice to have in your box but you have to hit hard to be able to break them. Maybe a pair of rear upright is also good to have because sometimes the screw of the upper link can damage them during a hard hit of the rear.
I would change the front alu axles to the steel ones they are expensive but it is a one time investment. The alu ones are just not hard enough.
The middle pulleys wear out after a while especially when you run low turn mod and the front drive shafts can be bent - but you can repair them.
You should have an extra set of belts also.
Mainly thats all.
cvt01 is offline   Reply With Quote
Xray T1FK05 $100.00 Charles R/C Items: For Sale/Trade 2 04-25-2006 10:51 AM
F/S: Xray T1FK05 ewippler R/C Items: For Sale/Trade 12 12-09-2005 04:03 PM
WTB: Xray T1FK05 ewippler R/C Items: Wanted to Buy 4 05-06-2005 06:40 AM
