Xray T1FK05
#2311
RCERIC...
Oops my bad, no one from XRay has stated they are stainless, though others posted that the screws are aluminum on the xray forums, while others suggested replacing the screws with stainless. The kit screws certainly don't weigh as much, nor have the same finish as the stainless replacements I bought.
#2313
Originally posted by kyle "hitawall"
i posted ealier that my car was loose off power. i thought it was fixed but now it is back to being loose. the car is great when the track is cool, but when the track heats up the car is crap. i tride putting more drop in the rear, going from 3 to 2 hples open in the front shocks, putting a front sway bar on, taking weight out of the front and also out of the rear, and also going from light blue to blue springs in the front.
#2314
Originally posted by Davo
Hi,
Has anyone got an idea of how to keep screws from stripping after a meeting? It seems every meeting i come home to re-build my car and the bulkhead screws seem to tighten them selves like welded or sumthing any suggestions on how to stop this?
Thankz Davo
Hi,
Thankz Davo
#2315
Originally posted by goop
this will fix the problem of the screws sticking and stripping out. take some thin ca glue with a cotton q-tip and put some ca in the counter sunk holes works beautifuly hope this helps
#2316
Hi,
Does anyone have any idea of how to keep screws from stripping after a meeting? It seems every meeting i come home to re-build my car and the bulkhead screws seem to tighten themselves like welded or sumthing any suggestions on how to stop this?
Thankz Davo
Hi,
Thankz Davo
#2317
Some of our local racers are now using associated springs with their fk05 and I've tried them with my fk04. The reasoning is the shorter length and more progressive rate. Anyone's thoughts on this???
Has anyone used HPI's progressive rate springs or any other brand spring with their xray's?
#2318
When I built my '05, I tightened all of the screws too tight, apparently. I had to dremel a slot in 3 of them to get them out, which mean that I have dremel marks on the bottom of that pretty new chassis after the first race day. Now, I only barely tighten them, and check them before each race - don't take that long to just hit all of them with the Hudy driver to be sure they aren't loose - no more problem with them being overtight, and this also makes me go over the entire car before each heat/main.
#2319
i have used congo springs in my 05 and the car was pretty good until there were a lot of 180s and chicanes. went to the xray springs and the car was even better.
#2320
#2321
#2323
Originally posted by Windsorguy99
http://teameamotorsports.com/ has them in stock right now I believe....great guy to deal with
#2324
Is anybody having glitching problems with the fk05? Mine is horrible, I've tried different receivers/positions etc etc. I have no problems with any of my other cars. It's driving me nuts...
#2325
