Like Tree1Likes
Xray T1FK05
Old 05-15-2005, 06:54 PM
  #2281
this will fix the problem of the screws sticking and stripping out. take some thin ca glue with a cotton q-tip and put some ca in the counter sunk holes works beautifuly hope this helps
goop is offline
Old 05-15-2005, 08:45 PM
  #2282
goop this will fix the problem of the screws sticking and stripping out. take some thin ca glue with a cotton q-tip and put some ca in the counter sunk holes works beautifuly hope this helps
What goop recommends is exactly what i did with the top deck on my mission a couple of years ago. It worked well. It must be that the screwheads are binding to the carbon fiber.
tadmj is offline
Old 05-15-2005, 11:55 PM
  #2283
I CA'd all my counter sinks, but the screws still seemed to tighten up. I noticed that the first teardown. Now they all seem fine.
MartynD is offline
Old 05-16-2005, 02:39 AM
  #2284
Default xray battery brace?
has anyone had any probs with tweak using the xray battery brace?
flysti is offline
Old 05-16-2005, 03:17 AM
  #2285
S-T-R-l-K-E-R's Avatar
no preb with tweak with my batt brace. it all fits fine just like the way the kit came together....effortless
S-T-R-l-K-E-R is offline
Old 05-16-2005, 04:22 AM
  #2286
Geetoo's Avatar
Originally posted by paulc
can't forget your first love ey?
You know pretty well, dont you
Geetoo is offline
Old 05-16-2005, 05:01 AM
  #2287
chach's Avatar
I have had no problems with tweak with my battery brace either........and do I love that thing, tape sucks.
chach is offline
Old 05-16-2005, 05:22 AM
  #2288
V12
V12's Avatar
Some question on front shock towers.
Whatīs the difference between the 302095 for foam tires and the 302096 as with the kit. I read itīs lower but how much is the difference and is it the same other than this?
V12 is offline
Old 05-16-2005, 05:55 AM
  #2289
gearchart.com rollout ? how come when you put in like 2.25 2.24 2.23 2.22 with the pinion and spur size it gives you the rollout number like i'm lookin for like around .98 to1.08 but if i put in like 57.15mm like it asks you for it'll give you numbers like 28.22 and really high numbers . and help would be great as i am new to carpet racing
rcfreak24 is offline
Old 05-16-2005, 06:21 AM
  #2290
sosidge's Avatar
That's because you when you put in a metric diameter you will get a metric rollout in the result. Don't mix your measurements!
sosidge is offline
Old 05-16-2005, 06:25 AM
  #2291
Jeff Werner's Avatar
Trader Rating: 27 (100%+)
Are people running the battery brace then? I would like to avoid tape if possible....lol
Jeff
Jeff Werner is offline
Old 05-16-2005, 06:48 AM
  #2292
I am using the battery brace and haven't noticed a tweak issue.
IMO it's much easier than the tape!
brianrice is offline
Old 05-16-2005, 06:59 AM
  #2293
yeah, thats good. sort of getting sick of the tape.
flysti is offline
Old 05-16-2005, 07:06 AM
  #2294
HarshGuy's Avatar
yepo!
HarshGuy is offline
Old 05-16-2005, 07:10 AM
  #2295
Regional Moderator
UnderDaHill's Avatar
Jeff
Wit a GTX and small speed control I'm underweight anyways. Might as well add the battery brace to avoid taping all the time. And for those of that hit our fair share of stuff the tape doesn't keep the cells from bowing up in the middle of the pack during impacts.
As soon as the BMI chassis is out I'll be switching to that since it will have a battery strap as part of the kit.
bob
UnderDaHill is offline
