Xray T1FK05
#2221
Originally posted by acutts
Can anyone help on how to build the X-ray shocks so that there is no rebound ... I must have tried about ten times now and just can't seem to do it ...???????????????
TIP: when you turn your shocks over for bottom cap bleeding (make sure the shaft if fully extended), use a standard Xacto blade horizontally or a ride-height gauge turned sideways as a means of stopping the shaft from going all the way in. So about a 1/4" or less. Then carefully close the cap making sure that the shaft doesn't move to prevent air from entering. After a while you'll find the sweet spot for perfect rebound and it will be dead on for each shock you build. Doing it this way, I can almost rebuild all four in about 20min.
Make sure to use the Xray aftermarket set of diaphrams, not the short hard ones that came with the 04 kit (dimpled to easily). I actually like the Serpent diaphrams with Xray foam inserts.
#2223
Originally posted by L.Fairtrace
I cant understand why you guys try to get no rebound. I have never felt the difference and it doesnt affect my cars performance. Do you think that little pressure from rebound is going to make a difference with 30lb springs on your car?
The best suspension setup ( i've seen from my friend's car ) :
The shock really absorb the weight of the car without bottoming out from 4 cm drop height. It should produce nice "absorbing" sound instead of "bang" sound.
You can see slight compression when you lift the wheel on opposite / diagonal side.
#2224
Originally posted by kidDynomite
It's alright to have some rebound. I believe Martin uses a ton, maybe even full rebound. As long as you do it consistently to all shocks all the time. You will be able to work with your rebound and find a consistant setting after every rebuild.
#2225
Originally posted by HRCRACER123
Can anyone recommend a good starting point as far as the shocks on med bite carpet. What colors? Thanks
#2227
Originally posted by dawgmeat
Since they come pre-filed will they work with 3700's or do you to filed them down?
Might have more luck asking this question with more specifics on the teamxray forum
Of course if you are asking about a BMI chassis... well try the BMI thread..
#2228
Stock & 19T Foams: F=Light-Purple/R=Dark Blue, No. 4 hole on front and rear towers, 3 holes open all around w/Xray 30wt.
Or better yet, go to:
http://www.teamxray.com/xforum/xsheets.php
#2229
Thanks for info ...... what does the x-ray foam insert do when used in the top of the shock?
#2230
The Thick chassis for the 05 does come with the battery slots pre-filed, and it will accomodate the new 3700 cells...if you use the xray battery strap, dont loose the shims that come with it becuase you will need those shims for the 3700 cells also.
#2231
Just to clarify, the foam insert goes in the diaphram. I believe it helps prevent the diaphram from "caving in" and staying that way.
it will also help the shocks provide more consistent rebounds
#2232
Originally posted by MartynD
Not sure what chassis you are talking about... the kit 05 chassis is not pre-filed, and from reports does not fit 3700's.
#2234
Originally posted by Geetoo
Thats true, tamiya first came out with it and works well.
