Like Tree1Likes
Xray T1FK05
Old 05-09-2005, 06:58 PM
  #2206
Hyperform Racing's Avatar
Originally posted by sonic31
will lowering the rear shock tower affect my roll center on my fk05 or am i ok on that one? just wondering
if the rear camber link angle changes, the roll center changes...
Hyperform Racing is offline
Old 05-09-2005, 07:03 PM
  #2207
sonic31's Avatar
Trader Rating: 6 (88%+)
it is a novice question from me but i just wanted to get other opinions on lowering the rear tower. thanks for the input
sonic31 is offline
Old 05-10-2005, 12:46 PM
  #2208
acutts's Avatar
Angry
Can anyone help on how to build the X-ray shocks so that there is no rebound ... I must have tried about ten times now and just can't seem to do it ...???????????????
acutts is offline
Old 05-10-2005, 12:52 PM
  #2209
Regional Moderator
UnderDaHill's Avatar
Originally posted by jdwca
Yeah, XRAY 30wt is around 50-55wt. in Trinity/Associated oil. I've never compared it to Losi. 60wt is a little too heavy for related use. I also generally prefer the XRAY oil to the Trinity equivalent. I find it to be a tick smoother and easier to work with.
As far as building the shocks, simply follow the instructions. I've built these shocks for a number of different kits. (Ask Tag, he's always getting me to build shocks for his cars.) They're actually really easy to build and super smooth. I never have air bubbles and generally I rebuild my shocks once a month.
Simply fill the shock to the top with the shock oil. Then, slowly push the piston almost to the top of its travel. Pull it back down very gently and then fill the rest of the body to the top with oil. Then, put the bladder on top (yes, some of the oil will overflow) and then put the shock cap on until it's fairly tight. Before you do ANYTHING, flip the shock upside down and compress a few times. The rebound will be too strong, SO, with the shock still upside down, you unscrew the bottom portion until it's off the shock body and then compress the shaft a few times until oil leaks out. Go ahead and screw the bottom cap back on and compress the shaft. You want very, very little rebound--if any. (I leave some in because inevitably the shocks lose some oil after a few runs.) Keep bleeding this way until you get the rebound you want. Remember, always keep the shock upside down when bleeding.
VOILA!--perfect XRAY shocks. Other than the Tamiya ones, they've been my favorite shocks to work with. [/B]
UnderDaHill is offline
Old 05-10-2005, 12:54 PM
  #2210
DougC's Avatar
Nevermind, UnderDaHill beat me to it.
DougC is offline
Old 05-10-2005, 12:58 PM
  #2211
acutts's Avatar
Originally posted by UnderDaHill
Thanks mate .... I think I know what I was doing wrong :-)
acutts is offline
Old 05-10-2005, 01:16 PM
  #2212
Regional Moderator
I have to build mine tonight so I was already trying to find some suggestions. I thought I'd just share the results of my search.
Old 05-10-2005, 02:41 PM
  #2213
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
I cant understand why you guys try to get no rebound. I have never felt the difference and it doesnt affect my cars performance. Do you think that little pressure from rebound is going to make a difference with 30lb springs on your car?
L.Fairtrace is offline
Old 05-10-2005, 03:20 PM
  #2214
Regional Moderator
I'm not too worried about a bit of rebound but I am worried about having a large difference between left and right rebound or having a LARGE rebound. I built the Xray T1M shocks (same shocks) a while ago and didn't have any problem with them.
But then again I'm used to the Associated nightmare shocks. :-)
Old 05-10-2005, 03:34 PM
  #2215
acutts's Avatar
I have found the removal of the bottom cap does allow the reduction of rebound but also allows air bubbles back in to the shock so is this a wise move?
acutts is offline
Old 05-10-2005, 03:43 PM
  #2216
mtveten's Avatar
Trader Rating: 29 (100%+)
When you hear people talking about removing the bottom cap during shock assemply what they are doing is over filling the shock and loosening the bottom cap when they screw the top cap on. At this point you turn the shock upside down and bleed the shock through the bottom and secure the bottom cap with the shock shaft fully depressed thus removing all air and setting the shock to no rebound.
Mark
mtveten is offline
Old 05-10-2005, 03:53 PM
  #2217
TeamPink91's Avatar
What kind of droop settings are a lot of you guys using on medium grip ashalt tracks as a starter setup?
TeamPink91 is offline
Old 05-10-2005, 04:46 PM
  #2218
NVisible's Avatar
nobody talking about the new FK05 parts?
http://www.teamxray.com/teamxray/new...f4efc43652452c
looks like some interesting adjustments to be had
NVisible is offline
Old 05-10-2005, 06:39 PM
  #2219
kidDynomite's Avatar
You want to make sure that you don't pull the shaft out then it suck air back in. You also don't want to remove the cap completely. Just unlock it and let it sit on the access oil coming out.
kidDynomite is offline
Old 05-10-2005, 06:42 PM
  #2220
HorshamRCRacing's Avatar
Anyone looking to get an XRAY T1FK 2005 Brand new in the box CHEAP!?
GO HERE!
http://www.horshamrcracingstorefront...?CategoryID=18
HorshamRCRacing is offline
