Like Tree1Likes
Xray T1FK05
Old 05-01-2005, 07:19 PM
  #2131
rcfreak...
www.gearchart.com
Using rubber tires and an Epic Roar stock I run a 21T pinion with the stock spur 84T. Think rubber tires are about 62mm diameter.
MartynD is offline
Old 05-01-2005, 07:52 PM
  #2132
Originally posted by =MisFitz= NuKe
On the issue of belt tension:
I have the front set on the most loose setting possible (the notch that has a big gap before it) and my front belt is still actually a little tight compared to my FK04. Any help will be appreciated.
Thanks,
Mike
Not sure how loose you really need it.... 1 notch looser than instructions feels fine to me. Have you run the car? The belts do stretch a little.
MartynD is offline
Old 05-01-2005, 08:07 PM
  #2133
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Ive been running my belts on the loosest setting since I got the car in stock and 19 turn and have had no problems and my tranny is free as can be.
L.Fairtrace is offline
Old 05-01-2005, 09:28 PM
  #2134
I'm getting my FK05 this week and was gonna pick up some of the Xray carbide thrust bearings. Are the one's they sell different from the one's they supply in the kit?
BTW these have been on the shelf before the fk05 came out.
NismoSkyline17 is offline
Old 05-02-2005, 03:19 AM
  #2135
As long as the thrust bearings have the copper colored retainer instead of the cheesy looking silver aluminum ones, you'll be ok.
skinart76 is offline
Old 05-02-2005, 08:20 AM
  #2136
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
My belts are in the loosest position front and one from the loosest in the rear. They don't feel as loose as my last XRay though. I've run them this way in both 19t and Mod without issue.
One thing I have noticed is that if you spin the spur by hand and watch the front belt...it will tilt from side-to-side as the pulley spins. Anyone else notice this? Any idea on how to fix it? I'm going to dig into it sometime this week.
Blake
dr_hfuhuhurr is offline
Old 05-02-2005, 10:02 AM
  #2137
NVisible's Avatar
my fk04 does the same thing. havent had any probs because of it
NVisible is offline
Old 05-02-2005, 10:05 AM
  #2138
John Doucakis's Avatar
Here is a modification I made to my Fk05 in order to save some space.
John Doucakis is offline
Old 05-02-2005, 10:08 AM
  #2139
close up on the steering arrangement.
The servo saver is glued.
Old 05-02-2005, 11:00 AM
  #2140
Awesome. Then I'm all set.
Old 05-02-2005, 11:06 AM
  #2141
Hi John,
Nice job! Your car looks really good with all of the red anodized stuff! Did you noticed any different in handling with the other servo position?
Best regards,
Jilles
Jilles is offline
Old 05-02-2005, 11:15 AM
  #2142
I cut the rear Servo ear off and used the front servo ears/mount and shoe goo to mount my servo in the normal position. That coupled with mounting the antenna on the upper deck, Gave me more room for electronics.
Blake
Old 05-02-2005, 11:48 AM
  #2143
Trader Rating: 14 (100%+)
John D.
Hi,
Nice looking install. is that a 9550 servo??? also what kind of speedo is that???
Dr_hfuhuhurr:
Hi,
is the belt moving from one side of the pulley to the other?? and does it do the same thing when you spin the spur gear backwards???
I had to tighten up the rear belt on both of my 04's as it would skip under heavy braking. I'm wiating for my 05 to show up so I can see how loose the belts are. ( so much for saving money for Karting ).
TimXLB is offline
Old 05-02-2005, 12:09 PM
  #2144
Jilles,
you got pm
I have not tested yet this layout. I will do so in 3 weeks as I don't have much time to practice.
TimXLB,
Yes this is the Futaba servo. The speedo is the NOSRAM Dominator Evolution , same exact ESC with the LRP Q2.
http://www.nosram.com/products.asp?id=25
Old 05-02-2005, 09:53 PM
  #2145
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Default Just got my T1fk"05 kit...
Hi guys I'm new in here and have a couple of questions. I am going to start to build my kit in the next day or two. Is there any suggestions when I am building it? I have done a little bit of research. As far as the dry diff If I just put some extra lube in it I should be fine right? And as far as the axial thrust bearing issue. I dont know what to do. I heard peoples were exploding. Should I just not even put in the one that comes with the kit and get a diffrent one? If so what one? Any other suggestions about any parts I should stock up on or any other key parts I should get. I think I will get the p-dub front bumper any other Ideas. I am not the best driver in the world but I do have fun. Sorry for all these questions but I know alot of you guys have alot more experience than me. Thanks guys..
HRCRACER123 is offline
