Like Tree1Likes
Xray T1FK05
Old 04-20-2005, 07:36 AM
  #1906
racingcivic's Avatar
Originally posted by =MisFitz= NuKe
Ronnie...
You dork, I set a new track record...you could have just looked at my car...I WAS pitting right next to you.
-Mike
could you share this setup with me. Really hurting for one to start with.
andy
racingcivic is offline
Old 04-20-2005, 09:21 AM
  #1907
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Originally posted by losixxxs
i am new to the xray does anybody have a good setup for the fk05 on carpet
Check the XRay site, there are a few starting setups there or ask people at your local track...I'm sure they will be glad to help.
dr_hfuhuhurr is offline
Old 04-20-2005, 04:05 PM
  #1908
=MisFitz= NuKe's Avatar
andy
Hey, for you, HarshGuy, and anyone else who wants decent asphalt starting set-up. I am going to fill out a set-up sheet and put it on here.
=MisFitz= NuKe is offline
Old 04-20-2005, 04:11 PM
  #1909
HarshGuy's Avatar
kewl
BTW I slapped some tamiya TRF shocks on my rig, looks sweet ..we'll see how they perform
here's some pics:
http://www.arroyoc.com/rcracing/harshshocksa.jpg
http://www.arroyoc.com/rcracing/harshshocksb.jpg
http://www.arroyoc.com/rcracing/harshshocksc.jpg
HarshGuy is offline
Old 04-20-2005, 04:40 PM
  #1910
polesitter61's Avatar
Where did you get that Kewl looking screw kit? I gotta have them!
polesitter61 is offline
Old 04-20-2005, 04:51 PM
  #1911
Default Set-Up
Alright guys, this is an asphalt set-up for 19 turn.
Before you go and try it, and say it sucks, remember each persons driving style is different. the car is very fast, I had to use brakes though going into the 180s, still working on that so I don't have to use brakes. Even if the car feels funny, this should be a decent, basic, set-up. I like my cars to feel very "on-edge".
-Mike
Old 04-20-2005, 04:53 PM
  #1912
stormperson's Avatar
Sweet car, who makes those blue shims? (like for toe and camber links)
stormperson is offline
Old 04-20-2005, 05:06 PM
  #1913
HarshGuy's Avatar
I "built my own" screw kit with blue countersunk washers & titanium button head & flat head screws from my LHS (Speedworld raceway in Roseville, CA) ...he didn't have all the sized I needed in stock, so got the rest from speedtech. The spacers are a Tamiya item ...I'm using them everywhere I need a spacer (e.g. rear arm spacers, bump steer steering arm spacer, etc...) http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXDEB4
HarshGuy is offline
Old 04-20-2005, 07:58 PM
  #1914
Midnight's Avatar
Trader Rating: 86 (100%+)
Default Re: Set-Up
What does running the rear arm mounts in the lower holes do to the handling.
-Mike
Midnight is offline
Old 04-20-2005, 08:42 PM
  #1915
Default Re: Re: Set-Up
edit...
basically what the guy below me posted...
Old 04-20-2005, 08:58 PM
  #1916
S-T-R-l-K-E-R's Avatar
using lower holes would give the car a lower roll center = more rear roll = more rear traction.
S-T-R-l-K-E-R is offline
Old 04-20-2005, 09:58 PM
  #1917
RCknight's Avatar
Default Can you move an the spur up/down....
on the 05 like you can on a RXD? Also can you only use Xray spur gears on the 05? Thanks
RCknight is offline
Old 04-20-2005, 10:21 PM
  #1918
scoobydo's Avatar
Default Re: Can you move an the spur up/down....
No, the spur already sits pretty low.
I use a 64p 116t Precision Racing System Spur in mine.
I heard the only spurs that are having a hard time fitting are the 64p Kimbrough ones.
They are too wide.
scoobydo is offline
Old 04-21-2005, 05:02 AM
  #1919
i use kimbrough spurs and they fit perfectly...IF you screw them on properly.
116t 64dp is the biggest you can get in without any modification to the chassis.
87t 48dp is the maximum you can go as well.
Old 04-21-2005, 05:10 AM
  #1920
Midnight's Avatar
Default Re: Re: Re: Set-Up
Im sorry but I was talking about the front arm rear mount, like Mikes ssetup sheet.
Midnight is offline
