Like Tree1Likes
Xray T1FK05
Old 04-19-2005, 09:03 AM
  #1876
Tim Stamper's Avatar
Another
Tim Stamper is offline
  #1877
Last
Old 04-19-2005, 09:20 AM
  #1878
JDXray's Avatar
ohh.... my.... fackking....god.... that is one sweet RED FK05!!!!
JDXray is offline
Old 04-19-2005, 09:23 AM
  #1879
Thraex's Avatar
Sorry, I can't talk right now.... my mouth's wide open!
I am stunned!
Thraex is offline
  #1880
JDXray's Avatar
I am stunned!
LOL SAMEEE
JDXray is offline
Old 04-19-2005, 09:28 AM
  #1881
hey now.... I was thinking about doing the exact same thing... same colour as well....
Anyways, did you notice any change in the fit of parts after getting that done Tim?
MartynD is offline
Old 04-19-2005, 09:38 AM
  #1882
All of the screws went in fine and the car still lays flat on the board. I forgot to put the battery strap posts in with the other parts, so they're done with red sharpie. Doesn't look too bad unless you touch the posts and the "Shapodizing" rubs off.
Tim
Old 04-19-2005, 09:39 AM
  #1883
I can't wait to strap a BMI chassis underneath the pretty red parts now. The wide upper deck helped out a ton but the 3mm chassis did nothing for lap times.
Tim
Old 04-19-2005, 09:49 AM
  #1884
i actually went 3 tenths faster with the 3mm deck and stiffer upper deck.
goop is offline
Old 04-19-2005, 09:51 AM
  #1885
Trader Rating: 51 (100%+)
Originally posted by Tim Stamper
What do you guys think?
Tim
It reminds me of the Xpress Pro chassis that I used to race a handful of years ago.
Apex is offline
Old 04-19-2005, 09:53 AM
  #1886
Did you do both at the same time?
I first tried the upper deck and I was able to shave off close to a half a second per lap.
I tested the chassis flex and it was almost gone. I picked up the 3mm chassis in a trade and slapped it on the car and the lap times were the same as with just the upper deck. Maybe it was just me, but the chassis didn't make a difference and it is $80 at the track and it isn't something that someone "really" needs to have on the car to make it fast. I will be offing my 3mm chassis when the BMI comes out and keeping the stock one as a spare.
Tim
Old 04-19-2005, 09:54 AM
  #1887
One of my friends and his brother used to run the express, that's why I decided to go red. Their cars looked trick and I wanted to try the same.
Tim
Old 04-19-2005, 10:01 AM
  #1888
dr_hfuhuhurr's Avatar
Trader Rating: 94 (100%+)
Tim
That rocks Tim! I have been e-mailing with an anodizer to get mine done in either Red or green.
Where did you have yours done? Cost? I was quoted $125 to get mine done. A bit pricy...but if it turns out half as good as yours...it's worth it!
Blake
dr_hfuhuhurr is offline
Old 04-19-2005, 10:11 AM
  #1889
kidDynomite's Avatar
Originally posted by duckman996
Isn't the servo side on a FK05 heavier or are you running 3700 packs? Am I reading this wrong
Just curious cause when I added weight I added more on the battery-side then I did on the electronics side to try to balance the car out (I run 3300 packs).
When I put my car on the wheel scales on all four corners, the rear end was dead even. The front left (servo side) was 10 grams lighter than the right. This was with 3300s. I guess it all depends on the equipment you run. I'm using a futaba digital servo, Novak Synthesized Rx and a GTX. With foams, it weighs in at 1386 grams with a kydex front bumber, PT between bumper and bulk heads, Tamale chubs and aluminum rear hubs, cut foams and body. I plan on putting a little more weight in the rear, but a bit more in the front. As is, it's on rails.
kidDynomite is offline
Old 04-19-2005, 10:33 AM
  #1890
duckman996's Avatar
Trader Rating: 14 (100%+)
I have pretty-much the same set-up (asside from the tamale chubs) ... I put a bit more weight at the back of the car when I added mine and found it pushed just a touch ... going to try putting more weight up front next time. For club racing, we have no weight limit so I am only going to add about 7 grams to the left-front of the car.
Thanks for the clarity -
Martin
duckman996 is offline
