Like Tree1Likes
Xray T1FK05
Old 04-18-2005, 12:48 PM
  #1861
John Tag's Avatar
Trader Rating: 42 (100%+)
I needed to add 95 grams with rubber tires and stock motor
John Tag is offline
  #1862
I had to add 3 quarters at a recent ROAR carpet regional.
It was like tenths of an ounce can't remember exactly.
Isaac is offline
Old 04-18-2005, 12:53 PM
  #1863
TeamPink91's Avatar
Figured it would be quite a bit of weight. Where did you put it?
TeamPink91 is offline
Old 04-18-2005, 03:39 PM
  #1864
side of the servo toward the front of the car which would be the left side of the servo (depending how you look)....
after that I was right at weight exactly 50oz.
airtronics whatever -57 servo
Keyence speed control
lightly painted one color Parma body
PCM futaba receiver....
Isaac is offline
  #1865
polesitter61's Avatar
Mine weighs 1485gms with a GT-7, Novak Syn. reciever, Hi-tech 945 servo, stock motor, one color Mazda 6 body. With rubber tires.
polesitter61 is offline
Old 04-18-2005, 03:47 PM
  #1866
duckman996's Avatar
Trader Rating: 14 (100%+)
Originally posted by RUKidn
yes it cood indeed be i do run my mesh loose so its not too tight i will tighten it up a bit
thnkx for that mate
If you mesh is too tight - the car will be noisy as well.
You may want to grease-up the thrust bearings as well while you're at it ... after I re-greased my diffs I did also notice a slight decrease in noise from the car.
Good luck - I hope you find the source of the noise.
Martin
duckman996 is offline
Old 04-18-2005, 03:58 PM
  #1867
duckman996's Avatar
Isn't the servo side on a FK05 heavier or are you running 3700 packs? Am I reading this wrong
Just curious cause when I added weight I added more on the battery-side then I did on the electronics side to try to balance the car out (I run 3300 packs).
Old 04-18-2005, 04:01 PM
  #1868
NVisible's Avatar
noisy cars eh? that must suck, my FK04 is dead silent
NVisible is offline
Old 04-18-2005, 04:29 PM
  #1869
=MisFitz= NuKe's Avatar
Originally posted by picco007
Does anyone have a good asphalt setup? Let me kow.
Ronnie...
You dork, I set a new track record...you could have just looked at my car...I WAS pitting right next to you.
-Mike
=MisFitz= NuKe is offline
Old 04-18-2005, 04:44 PM
  #1870
duckman996's Avatar
You must be Canadian ... eh
Actually, after I re-lubed the diff, the car is as quiet as the FK04 was.
Old 04-18-2005, 04:53 PM
  #1871
NVisible's Avatar
last time i checked
glad the 05 is working for ya
NVisible is offline
Old 04-18-2005, 05:18 PM
  #1872
TeamPink91's Avatar
I am thinking about putting a screw in the bumber top plate and screwing 20g of chassis weights into it upside down so they sit inside a hole cut out in the bumber, and 10g on each side in the rear just to get some weight on the car. How does that sound?
Old 04-18-2005, 05:21 PM
  #1873
HarshGuy's Avatar
Originally posted by =MisFitz= NuKe
Ronnie...
-Mike
So kick down the setup bro!!
HarshGuy is offline
Old 04-19-2005, 09:00 AM
  #1874
I had to add weight to make the limit to my car. I added 1/2 oz at the rear on each side just in front of rear wheels where chassis widens. 1.25 oz along centerline or as close as i could get it, and if you remove the bumper top plate u can stick 1/2oz on the chassis then remount the top plate.
I used stick on weights in 1/2, and 1/4oz sizes
MartynD is offline
Old 04-19-2005, 09:02 AM
  #1875
Tim Stamper's Avatar
What do you guys think?
Tim
Tim Stamper is offline
