Like Tree1Likes
Xray T1FK05
Old 04-17-2005, 05:33 PM
  #1846
Default front diff halves
I broke a right front caster block today that caused the axle bone to bend and that pushed the bone into the outdrive causing it to mushroom out. Now from looking in the manual it looks as though you have to buy a whole diff assembly. Does anyone know if you can by the halves or the spring steel units seperately
Andy C is offline
Old 04-17-2005, 05:52 PM
  #1847
polesitter61's Avatar
Check the X-ray forum, Mario just listed the part #'s for someone else.
polesitter61 is offline
Old 04-17-2005, 07:16 PM
  #1848
RoNTC3's Avatar
What's the deal with the shocks??? Is everyone running the plastic adjustable or alum or other brands??
RoNTC3 is offline
Old 04-17-2005, 07:47 PM
  #1849
Kit ... Page me... I have ten of those diffs... Sound like you need all of them...
Stoke
Stoke II is offline
Old 04-18-2005, 12:07 AM
  #1850
Hi ppl i ran my fk 05 for the first time. The problem i found was that it seemed to squeel alot liek the diffs high pitch noise. I even took them apart before i ran and lubed the 12 balls up BUT NOT THE THRUST BEARINGS
Cood it be that teh thrusts are dry in which it makes a squeeling noise under acceleration? if so do i need circlips to take that clip off to get to the thrust bearings??
RUKidn is offline
Old 04-18-2005, 02:59 AM
  #1851
komkit's Avatar
Stoke
Thanks Stoke, I'll give you a page later on. For some reason we can't connect and if you coming up to Mimi's this wed, I'll stop by.
Yeah, if you want to sell me two set of those.
komkit is offline
Old 04-18-2005, 04:17 AM
  #1852
duckman996's Avatar
Trader Rating: 14 (100%+)
That squeeling could be your pinion to spur mesh is too tight ... or your pinion is too worn-out. You may want to check that.
If you are ruinning 48-p gears, try tightening your pinion to your spur with a sheet of paper in-beween the two giving you a 0.5 mm gap. Once you are done tightening down the motor screws, roll the spur gear so that you remove the pinion and you should have a perfect mesh.
Maritn
duckman996 is offline
Old 04-18-2005, 04:33 AM
  #1853
yes it cood indeed be i do run my mesh loose so its not too tight i will tighten it up a bit
thnkx for that mate
RUKidn is offline
Old 04-18-2005, 05:21 AM
  #1854
kewdawg's Avatar
Guys,
I ran the 05', yersterday. One word.... DIALED! After working out all the bugs.
kewdawg is offline
Old 04-18-2005, 05:32 AM
  #1855
picco007's Avatar
Trader Rating: 99 (100%+)
Does anyone have a good asphalt setup? Let me kow.
picco007 is offline
Old 04-18-2005, 07:08 AM
  #1856
rpoage's Avatar
Default Re: Re: Aluminum Front Hubs/Axles
Originally posted by komkit
Where would I find them spring steel stuffs in US?
Can't seem to find hobby shop that got them in stock.
Anyone know where to get the SS outdrive or just solid alu outdrive (I think # 30 5010) please let me know.
True X-Ray/R.C. America has removed the XRA 305015 & XRA305025 from their price list. We have one set left in stock.
We also stock the XRA305015 SS Diff Out Put Shaft-Long
rpoage is offline
Old 04-18-2005, 08:05 AM
  #1857
picco007 - I used the rubber tire carpet setup as a base for an asphalt. About the only thing that I have done is use the outside hole on the rear hub and I removed the two front alum standoffs that go from the upper deck to the chassis. You will need to put a spacer under the tie rod on the hub carrier. I used a 2mm sapcer. I ran this weekend using that setup, the setup was really good. I was able to run down and pass guys that I usaully can just keep up with. The car is awesome so far.
Later, Lee
LeeS is offline
Old 04-18-2005, 10:56 AM
  #1858
serpentracer1's Avatar
Yea Komkit I've been trying to page him to get 2 sets for my car seems like he doesnt answer his page anymore.Been trying to get ahold of STOKES since sat.I must not rate on his list.
serpentracer1 is offline
Old 04-18-2005, 11:04 AM
  #1859
My car was noisey after greasing the diff balls only, once the diff was dismantled and the thrust bearings greased it became much quieter.
MartynD is offline
Old 04-18-2005, 12:46 PM
  #1860
TeamPink91's Avatar
Anybody know a rough estimate of how much weight people are having to add to make the 05 ROAR legal (1525 grams)?
TeamPink91 is offline
