Like Tree1Likes
Xray T1FK05
Old 04-15-2005, 07:45 AM
  #1786
John Fontaine's Avatar
Originally posted by dway100
Couldn't you just put the cutouts towards the middle of the car? That way they won't be visible. Just a thought.
Yes you can, and I would do it that way....but now I know about it and it would bug me every time I think about it. I'll use tape and sell it Plus having the battery hold down makes it harder to put in motors and such.... That's just my $.02 cents...please come to your own conclusions
John Fontaine is offline
Old 04-15-2005, 07:57 AM
  #1787
HarshGuy's Avatar
I turned them inward and the don't look to bad, I'm gonna tell people it's by design to increase air flow and drivetrain efficiency ...or I'll come up with some ghetto way to fill in the cutouts
HarshGuy is offline
Old 04-15-2005, 09:37 AM
  #1788
RobertV's Avatar
Default Re: PRS Gears
Originally posted by EAMotorsports
Hey Guys I got all the PRS gears in stock for the Xray FK 05. But they probably wont last long!! 112, 114, 116's.
EA
Gears are great, but are useless withought pinions. Any idea when PRS will replenish the supply?
RobertV is offline
Old 04-15-2005, 09:44 AM
  #1789
HarshGuy's Avatar
Default Re: Re: PRS Gears
HarshGuy is offline
Old 04-15-2005, 09:51 AM
  #1790
RobertV's Avatar
HAHAHahahHAHAHHAHaHaAHa!
Damn you HarshGuy, stop stalking me!
Don't you have a diff to build or some tires to mount or something? Stop wasting time on the forums and go spray some traction on the track I'll be there as soon as I get my parts from the big brown truck today.
RobertV is offline
Old 04-15-2005, 10:03 AM
  #1791
HarshGuy's Avatar
...actually diff's built, motor guard mounted, battery brace installed ...heading out at 10:00am to blow off the track and lay some rootbeer down, I didn't put the multidiff in yet cause I want to time my run with diff, them multidiff, then locked multidiff
HarshGuy is offline
Old 04-15-2005, 10:11 AM
  #1792
tboned_2002's Avatar
must be nice to have the track to yourself! you bought the motor gaurd ehhhh? Did you buy enough parts to get DAL back on the track as well?
tboned_2002 is offline
Old 04-15-2005, 10:19 AM
  #1793
HarshGuy's Avatar
..Dal has plenty of parts, if I could buy some motivation then we'd be set
HarshGuy is offline
Old 04-15-2005, 12:45 PM
  #1794
dal bains's Avatar
Trader Rating: 37 (100%+)
Default hey hey
I have some personal stuff going right now, but after next week, I will be out again. Also changed positions at work but the old position still knocks at my cube for help, so a lot of OT.
dal bains is offline
Old 04-15-2005, 02:00 PM
  #1795
Does anyone have any contact info for rubberneck racing bumpers???? are these anything like the old td enterprises protector bumpers????
Thanks in advance
R Monahan is offline
Old 04-15-2005, 02:04 PM
  #1796
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Here you go...Direct to Rubberneck. A page I put up for him.
http://www.2brainsdesign.com/2brains...rubberneck.htm
dr_hfuhuhurr is offline
  #1797
wannabee's Avatar
Thanks Blake!
Rubberneck bumpers at www.pdubracing.com pix etc...
Thanks,
KE
wannabee is offline
Old 04-15-2005, 06:37 PM
  #1798
meeuwsmi's Avatar
I just got my 05 built and took my time with everything, especially the shocks, and I relubed the diffs also. I have a small problem though. The belts don't seem to line up well. The front belt is towards the right side of the diff pulley in the front. It rubs the edge of the pulley and makes a little noise and I feel creates some drag. The rear belt is the same way as the belt is on the left side of the pulley on the diff. I can't figure out why this does this or what could be out of alignment.
meeuwsmi is offline
Old 04-15-2005, 07:35 PM
  #1799
Hey mate, make sure you got the diffs going into the bulkheads in the right way as there is a specific way with the longer sides, check the belt tensioner positions that they are all the same and turn the spur so when the diffs so u can see the diffs spinning to see if the are turning alrite not all wonky.
RUKidn is offline
Old 04-15-2005, 08:02 PM
  #1800
Default Carbide thrust bearings
Anyone know where I can get the 309072 carbide thrust bearing assembly? Either an online hobby shop or someone willing to part with an extra they might have.
Maybe I should ask if they are even out yet. I have looked at stormer and they are out of stock. Or I should say "on order".
Any info would be great.
Thanks in advance. Chris
ccm399 is offline
