Like Tree1Likes
Xray T1FK05
Old 04-10-2005, 05:22 PM
  #1636
=MisFitz= NuKe's Avatar
Originally posted by RUKidn
i got a 2mm wrench thats it, is that whats mainly used for chassis components like top deck and bulkhead attachments?
2mm is the main one yes...but, you do need the others mentioned, 3mm to put the shocks on, 1.5 for small set screws, and 2.5 for wheels
=MisFitz= NuKe is offline
Old 04-10-2005, 05:28 PM
  #1637
polesitter61's Avatar
What replacement thrust bearing are you guys using for the faulty stock one? I just got mine and have not raced it yet but don't want to have a problem. Thank you in advance.
polesitter61 is offline
Old 04-10-2005, 05:34 PM
  #1638
drx
drx's Avatar
Losi makes a very nice wrench set with those 4 sizes.
Now if I could find a nice 5mm open-end for the connecting rod ends.
drx is offline
Old 04-10-2005, 05:35 PM
  #1639
Originally posted by John Fontaine
more holes means things are weaker and it would break like a HPI
are you serious? under those words that sounds like a car should be full of holes then lol. my old hpi is a monster when you wanna talk about durability
greencactus3 is offline
Old 04-10-2005, 05:38 PM
  #1640
Hey...I am sorry, but I just can't stop laughing at all these issues you guys are complaining about with the diffs and the spur gears. Let's see....my kimbrough gears work perfectly fine, don't rub at all, they get close, but don't rub...and the whole thing with the diffs. I have never had a problem with the Xray diffs going bad or getting gritty or anything. Maybe you guys are doing something wrong with your break-in procedure???
Old 04-10-2005, 05:56 PM
  #1641
Nuke...
The diffs come with either none or virtually no lubrication in them.
I pulled the diffs apart and found very little silicone grease on the balls, but I didn't have the snap ring pliers to try and look at the thrust bearing. So i added grease to the balls and that was it... yet my car was noisy, after following the break-in procedure outlined in the manual.
Someone else offered to pull the diffs apart for me who had the correct tools.... yup the thrust bearings were dry. Once correctly greased up the diffs are sweeeet!
Haven't tried any other spurs but stock yet but I am tempted to try. I have lots of 48p pinions , but I will start collecting the 64's soon.
MartynD is offline
Old 04-10-2005, 06:07 PM
  #1642
HarshGuy's Avatar
I've been using a little screwdriver and packing grease into the thrust bearings ...till I get one of them snap ring chingaderas.
Originally posted by MartynD
Nuke...
HarshGuy is offline
Old 04-10-2005, 06:10 PM
  #1643
John Fontaine's Avatar
Snap ring pliars make getting the snap ring off really easily IMO, you need one in your toolbox if you seriously race the Xray
John Fontaine is offline
Old 04-10-2005, 06:16 PM
  #1644
how do u get teh grease in with the srewdriver way? do use recomend i pull the diff apart wehn i build t to lube the diff balls and thrust bearing? and is it possible to get snap thign off wit pliers or wll i rek sumtin
RUKidn is offline
Old 04-10-2005, 06:28 PM
  #1645
HarshGuy's Avatar
Just with an "itty bitty" scredriver ...yea I keep meaning to try and find one of them snap ring chingaderas, never had to get one, where would I find one? Is that just a home depot thing? ...I purchased a spring steel diff and all the parts were "apart" so that was was cakewalk to grease up and assemble, it's just the assembled ones that came with the kit that I gave "the screwdriver treatment" to ....but heck this week I'll only be runing 1 diff anyways
HarshGuy is offline
Old 04-10-2005, 06:34 PM
  #1646
duckman996's Avatar
Trader Rating: 14 (100%+)
Before you assemble the car, take apart the diffs and lube them ... that way you won't run into any problems. As for using pliers, you may actually bend the c-clip that holds everything together if you use that. I have a set of side cutters that work perfectly for the application and have been using them. When I have a moment, I am going to get the correct tool for the job.
As for incorrectly breaking the diff in, I can assure you that the break-in procedure is not the problem - rather, it's the fact that the balls in the diff do not come with the adequate lube. According to X-Ray they are going to have a comment on their website regarding this problem on Monday.
duckman996 is offline
Old 04-10-2005, 07:10 PM
  #1647
wannabee's Avatar
Has anyone noticed this car to be loud? The bearings seem to be 89.9999% of the cause...IMO
KE
wannabee is offline
Old 04-10-2005, 07:19 PM
  #1648
Harsh you can get snap ring pliers from Kragen that is were I got pliers from.
bigdog is offline
Old 04-10-2005, 07:28 PM
  #1649
HarshGuy's Avatar
saweet ..thx!!
HarshGuy is offline
Old 04-11-2005, 01:33 AM
  #1650
i started to build my x ray i have stripepd one of the screws that attach into the rear bulkhead form underneath. How can i get it out?
RUKidn is offline
