Like Tree1Likes
Xray T1FK05
Old 04-09-2005, 10:42 AM
  #1621
kewdawg's Avatar
Originally posted by tc3Guru
can anyone elaborate on xray's shock setup and get me some good pics and which "something in there to change" to start with on -onroad carpet?
I've mainly dealt with AE shocks these are high tech to what I'm use to.
Xray 30 or 40wt. oil, Xray light purple (30lb.) springs, 2 holes open on pistons (front & rear). Use outer hole on front shock tower and use 2nd hole from the outside on rear shock tower. Use middle hole on rear arm - rear arm mod in manual has not been sucessful for many.
kewdawg is offline
Old 04-09-2005, 06:45 PM
  #1622
duckman996's Avatar
Trader Rating: 14 (100%+)
Default Re: Thrust
Originally posted by aantonis
I just changed mine today with a new one.
The factory-pre-installed-crappy-thrust broke in pieces.
Sh*%
I installed the good one now. It works fine. Anyone who hasn't change it so far, better think about doing so cause it will fail sooner or later.
Yup ... mine failed as well. As much as I love the car, finding the "cheap-out" thrust bearing was a bit of a disappointment. None are available in my area right now so I have to wait to replace with the good ones.
duckman996 is offline
Old 04-09-2005, 07:18 PM
  #1623
mine fell apart too and i found out that the losi thrust bearing in the cage for the xxx-s fits and works perfect and lasts
goop is offline
Old 04-09-2005, 07:38 PM
  #1624
komkit's Avatar
My thrust bearings blew up as well. Same goes with the guy sitting next to last week at the regional race.
My retainer ring in the front diff was GONE! The rear the balls just fell off from the retainer ring.
Boca bearing made the good one also, Corally, Kyosho 30 size helicopter tail blade thrust bearing......shouldn't be hard to find a replacement.
Otherwise FK 05 is the car of the year!
komkit is offline
Old 04-09-2005, 07:48 PM
  #1625
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
There is a middle hole on the rear arm?
L.Fairtrace is offline
Old 04-09-2005, 08:24 PM
  #1626
John Tag's Avatar
Trader Rating: 42 (100%+)
He was looking at his HPI
John Tag is offline
Old 04-09-2005, 09:40 PM
  #1627
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Default Blown thrust race
any of you guy`s ran the diff out of the box
or did you take apart redone it as they say??
MR JOLLY is offline
Old 04-09-2005, 11:22 PM
  #1628
buboy28's Avatar
Originally posted by scoobydo
It was ages ago! (as far as threads go! )
It was page 29, 7th from the bottom.
found it, thanks bro
buboy28 is offline
Old 04-10-2005, 05:19 AM
  #1629
kewdawg's Avatar
Well Tag and Larry, I guess I was THINKING, Hpi. I meant to say, use the inside hole. Then again, maybe my sub-conscience was pointing out, that there SHOULD BE a third hole?
kewdawg is offline
Old 04-10-2005, 08:51 AM
  #1630
hpipro321's Avatar
Default Diff out of the box
i ran the diff out of the box and then i tightened it while it was in the car so i could get just the right fell i wanted
hpipro321 is offline
Old 04-10-2005, 11:10 AM
  #1631
MR JOLLY's Avatar
Default DIFF
I take mine apart & regrease them with yoke black grease (thrust) , yoke silicon (diff balls) done this on the fk04 & 05 no diff problems at all with both cars
MR JOLLY is offline
Old 04-10-2005, 03:58 PM
  #1632
John Fontaine's Avatar
more holes means things are weaker and it would break like a HPI
John Fontaine is offline
Old 04-10-2005, 04:25 PM
  #1633
MY X-ray FK05 will be here today, any tips for building it?? what is teh main ex driver size used?? 2mm?? or what common ones are needed
help asap
RUKidn is offline
Old 04-10-2005, 04:44 PM
  #1634
duckman996's Avatar
RUKidn,
To build the car you will need a 1.5, 2,2.5, and 3 mm hex wrenches. Rebuild the diff as soon as you get the car to avoid any problems (most kits seem to come with a dry diff and dry thrust bearings).
Old 04-10-2005, 04:56 PM
  #1635
i got a 2mm wrench thats it, is that whats mainly used for chassis components like top deck and bulkhead attachments?
RUKidn is offline
