Like Tree1Likes
Xray T1FK05
Old 04-08-2005, 09:16 AM
  #1606
NVisible's Avatar
Originally posted by John Doucakis
Tamiya shocks fluorine coated..
Any Tamiya or Xray spring will fit just fine.
A few pages back I posted a list of parts needed to mount TAMIYA shocks on Xray kits.
got them, do you have part numbers for the red collar & spring holder (bottom thingy)?
NVisible is offline
Old 04-08-2005, 09:19 AM
  #1607
Qwiglee's Avatar
Thrust bearings are the ones that provide the tension to the diffs...not the 2 little metal shielded bearings that the diff gears ride on.
Qwiglee is offline
Old 04-08-2005, 09:22 AM
  #1608
big_G's Avatar
Originally posted by HarshGuy
OK let me rephrase that, is there any hobby shops outside of the US that can get a hold of a 305102 and ship it to the US?
Try here
big_G is offline
Old 04-08-2005, 09:30 AM
  #1609
DougC's Avatar
I am aware of that. I was referring to the thrust bearings installed in the long side of my diffs, not the ball bearings that the diff gears ride on.
DougC is offline
Old 04-08-2005, 09:45 AM
  #1610
The old thrust bearing had a brass (or copper) cage. the difference is obvious.
According to the manual this carbide bearing should be in the diff:
http://www.teamxray.com/teamxray/pro...62&kategoria=0
cvt01 is offline
Old 04-08-2005, 09:47 AM
  #1611
DougC's Avatar
That's not what is in my diffs, that's for sure.
DougC is offline
Old 04-08-2005, 10:22 AM
  #1612
Qwiglee's Avatar
Where can i get some thumb screws for use on the Hudy setup board so I dont use the regular wheel screws? They would be M4x8.
Qwiglee is offline
Old 04-08-2005, 11:11 AM
  #1613
duckman996's Avatar
Trader Rating: 14 (100%+)
Not in mine either ...
Time for a rebuild anyway -
duckman996 is offline
Old 04-08-2005, 11:17 AM
  #1614
ChrisP's Avatar
Check uor local fastener supply shop for M4 shoulder bolts
ChrisP is offline
Old 04-08-2005, 12:22 PM
  #1615
Eric Gebhard's Avatar
Try McMaster Carr www.mcmaster.com
Eric Gebhard is offline
Old 04-08-2005, 12:54 PM
  #1616
kidDynomite's Avatar
Quiglee, I just bought some regular Integy setup wheel nuts ($10 for a set of 4) and thread locked some long set screws into them. Makes for some really quick adjustments.
kidDynomite is offline
Old 04-08-2005, 08:42 PM
  #1617
buboy28's Avatar
sorry for asking but what page i cant seem to find it
buboy28 is offline
Old 04-08-2005, 09:03 PM
  #1618
scoobydo's Avatar
It was ages ago! (as far as threads go! )
It was page 29, 7th from the bottom.
scoobydo is offline
Old 04-09-2005, 12:04 AM
  #1619
can anyone elaborate on xray's shock setup and get me some good pics and which "something in there to change" to start with on -onroad carpet?
I've mainly dealt with AE shocks these are high tech to what I'm use to.
tc3Guru is offline
Old 04-09-2005, 09:59 AM
  #1620
Default Thrust
I just changed mine today with a new one.
The factory-pre-installed-crappy-thrust broke in pieces.
Sh*%
I installed the good one now. It works fine. Anyone who hasn't change it so far, better think about doing so cause it will fail sooner or later.
aantonis is offline
