Like Tree1Likes
Xray T1FK05
Old 04-07-2005, 05:14 AM
  #1576
Michal101's Avatar
Originally posted by S-T-R-l-K-E-R
have a little bit of problem when exiting. the rear end tends to step-out when you exit hairpins causing the car to loose forward motion when you go on the throttle. can anyone give any tips?
Your current setup is important as previously posted, but many times with a new car one of the diffs will become loose and in your case a very loose front diff will casue the problem you are referring to in your post. This is casued since the front end cannot pull the rear end out of the corner.
Also, what type of track are you running on and what type of tires?
Michal101 is offline
Old 04-07-2005, 05:33 AM
  #1577
Tim Stamper's Avatar
I have a slight issue. I decided to check the diffs since I have run my '05 a bunch of times and am starting to run hotter and faster motors. I wasn't too surprised to see bone dry diffs after reading some posts a few pages back. I was surprised to see only 11 diff balls in the front. I know I won't notice too much of a difference, but it's just my luck to be missing a little part like that. The car still works great though. Oh well.
Tim
Tim Stamper is offline
Old 04-07-2005, 05:44 AM
  #1578
John Fontaine's Avatar
You were missing a dif ball? Contact RC America.
John Fontaine is offline
Old 04-07-2005, 05:56 AM
  #1579
one ball is nothing... from mine one bearing was missing, totally dry, and the thrust wasnt the original X-RAY one... the one that was delived with all the previous models and as spare part.
harris is offline
Old 04-07-2005, 05:59 AM
  #1580
I'm gonna send them an e-mail, but the car works great, so i'm just gonna let them know about the discovery, not complain about it.
You should definately contact Rc America.
Tim
Old 04-07-2005, 06:03 AM
  #1581
Tim i bought it from Europe..... did you check your thrust bearing...
harris is offline
Old 04-07-2005, 06:38 AM
  #1582
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
So you're saying you're one ball short of a full diff...
dr_hfuhuhurr is offline
Old 04-07-2005, 06:44 AM
  #1583
wannabee's Avatar
UNLIKE YOU, ONE BALL SHORT OF BEING A MAN!!lol
wannabee is offline
Old 04-07-2005, 07:14 AM
  #1584
stormperson's Avatar
Actually on the topic of being one ball short of a full diff...
When i built my 04 around the first of the year, i lost a ball trying to lube the diff, anyway, the diff is still money without being touched, and I have run the novak race, regional and national, and a BUNCH of club racing inbetween, so I wouldnt be worried about it. Although it is a good idea to lube the diff up, both diff lube for the balls and also black grease or the like for the thurst bearing, since its like they just put bearing oil in the diff to lube it at the factory...
stormperson is offline
Old 04-07-2005, 07:38 AM
  #1585
HarshGuy's Avatar
Is the multidiff available (as a spare part) outside of the US anywhere?
HarshGuy is offline
Old 04-07-2005, 07:54 AM
  #1586
Sorry, I didn't see your location before I posted it. X-ray should be notified though. I didn't check the thrust bearing. I will check it later on tonight and let you know.
I will actually say, thank you for that post.
Work is stressing me out to the point where i'm gonna pop and that post helped out a little. Just a little.
I noticed that it felt the same at the rear and wasn't too worried. It still is as smooth as can be and doesn't slip.
Later,
Tim
Old 04-07-2005, 09:30 AM
  #1587
big_G's Avatar
XRAY MULTI-DIFF T1, T1EVO2, T1R, T1M, T1FK Part No: 305103
XRAY MULTI-DIFF T1FK'05 Part No: 305102
You'll have to check LHS for availability
big_G is offline
Old 04-07-2005, 09:53 AM
  #1588
NVisible's Avatar
Default Re: Chassis weights...
Originally posted by MartynD
My assembled FK'05 comes in at 1444g... I need to add 56g for a race this weekend. I rarely stray outside of club racing where its run what ya brung, so I can't justify shelling out the $$ for the XRay weights.
Anyone have any suggestions?
Anyone have any experiences to share about ideas they have tried in the past? (successful or unsuccessful)
Instead of adding clunky weights, add some weight that may do you some good, like fans! Im sure an LHS down there has something you can use
NVisible is offline
Old 04-07-2005, 10:06 AM
  #1589
HarshGuy's Avatar
OK let me rephrase that, is there any hobby shops outside of the US that can get a hold of a 305102 and ship it to the US?
HarshGuy is offline
Old 04-07-2005, 11:24 AM
  #1590
RobertV's Avatar
HarshGuy is looking for someone to smuggle it into the states!
RobertV is offline
