Xray T1FK05
#1561
Originally posted by NVisible
Interesting. Does that not create a big forward angle on the shock? Also, what do you expect to accomplish by doing this?
I have the exact same car as you and am curious
#1562
Originally posted by John Fontaine
Interesting Jon... Never seen that before. I would think that would cause the shock angle to be severe and cause binding. What's the reason for having the shock like that??
BTW - Nice chassis and cells, and you're missing a receiver in that picture...you can't race like that
#1566
What size spur are most of you guys going to when making the conversion to 64 pitch on the '05?
#1567
prs 116
#1568
Guys, Jon has the right idea when it comes to converting the position of the shock to the front--in least in regards to the sweep angle of the shock.
When you run the outer hole on the arms and dremel down the arm to make way for 28mm tires, the angle of the shock is extreme. That's one reason I never ran the outer hole on the arms even on carpet. It just didn't feel smooth enough--had a weird feeling to it.
If you notice from the pictures, the angle of the shock is now right.
#1569
Like you said about the outter hole, i dont like it either. The inner just seems more stable.
Gonnaa try the setup with the shocks and the new cells hehehhe
#1570
My assembled FK'05 comes in at 1444g... I need to add 56g for a race this weekend. I rarely stray outside of club racing where its run what ya brung, so I can't justify shelling out the $$ for the XRay weights.
Anyone have any suggestions?
Anyone have any experiences to share about ideas they have tried in the past? (successful or unsuccessful)
#1571
Sorry Double post
#1572
Originally posted by JDXray
I was still thinking if i should dremel the arm, just to make the shocks stand up more vertical and not on an angle so much.
#1573
have a little bit of problem when exiting. the rear end tends to step-out when you exit hairpins causing the car to loose forward motion when you go on the throttle. can anyone give any tips?
#1574
whats your setup
#1575
You can go to Walmart tire center and get some balancing weights and put an 1/4 on each part of the chassis. I think 1 once equals 28 grams.
