Old 04-11-2012, 04:46 AM   #16
MrUnlimited's Avatar
Originally Posted by hanulec View Post
+10000
note- not all 65c packs are created equal. It varies from manufacturer and each model they produce.
Your options are to test all of the packs yourself or just pick what is "fast" and hopefully reliable (will be fast for more than 10-15 charges)
I know my choice
+1 run some test throught various packs to decide which one gives the best power.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-11-2012, 09:11 AM   #17
Mr RCTech's Avatar
Forget about C ratings on labels...
Mr Unlimited is RIGHT!
Its all about IR (internal resistance) the lower the better the lipo battery pack.
Cheaper lipo packs are hit or miss when getting a good pack with really low IR.
In blinky mode its even more important to have a lower IR due to the high timing in the can that lowers motor efficiency.
Graph your batteries to see the drops in voltage under a high amp draw, and compare your packs to see which packs are really good.
Mr RCTech is offline   Reply With Quote
Old 04-11-2012, 09:32 AM   #18
Trader Rating: 38 (100%+)
Buy whichever battery is most expensive. Then you can't use budget as an excuse for losing.
or8ital is offline   Reply With Quote
Old 04-11-2012, 10:42 AM   #19
Regional Moderator
CarbonJoe's Avatar
Listen to this man. He speaks from experience.
In all seriousness, there is a thread on here with several comments from Danny from SMC stating that most of the ratings above 40C are likely BS. There are only a few manufacturers in China that actually produce the LiPo cells, so the performance difference comes down to quality control, and fancy packages.
For the large majority of club racers, none of this really makes a difference on the track. Buy a brand that you can afford and feel good about buying.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
