Old 01-30-2005, 04:35 PM   #1
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
Default Opinions on the Yokomo SSG
I am curious if anyone here has run the SSG and how good of a car it is. I currently have a FT TC3 and am looking to get something better. I would like to know things like how easy it is to work on, to setup, parts wear, parts availability etc. Any help would be greatly appreciated!
RCNitroDude999 is offline   Reply With Quote
Old 01-30-2005, 04:39 PM   #2
Send a message via AIM to Johnnytc3
Read the last couple of pages of the yokomo thread, im in the same boat you are and am leaning towards the CGM.
Johnny
Johnnytc3 is offline   Reply With Quote
Old 01-30-2005, 04:43 PM   #3
Default Re: Opinions on the Yokomo SSG
IMO the CGM is a better all around car. It would also be closer to the TC3 you are running now. It is very easy to work on, box set up is a very good starting point. Parts availability is of course better if your LHS carries parts. Speedtech located on these boards supports the Yokomo very well as does Speedworld Raceway. The car no longer has many weak points as it did when it first came out, Yokomo is always improving product. Much like any TC, extra parts like arms, casterblocks and steering hubs are needed. Check out the support on the Yokomo thread on these boards, lots of good info and help.
pops is offline   Reply With Quote
Old 01-30-2005, 08:07 PM   #4
Joel Lagace's Avatar
I ditched the TC3 for 2 SSG cars. A total world of differences for me:
-diff access faster
-hing pin the size of ever other car 3mm(AE pins where tiny)
-battery more centralized almost touching the shaft
-Once the Buds bumper was installed breakage was far and few between
-on the track it seemed more consistant from run to run.
-it just plain looked kool
I did add TC3 lower shock hardware to the yok shocks so i could continue using my 9pack of AE springs
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-30-2005, 09:00 PM   #5
Registered User
ritchie's Avatar
Default Re: Re: Opinions on the Yokomo SSG
ditto
ritchie is offline   Reply With Quote
M-04 Opinions Dorigecko Electric On-Road 62 10-10-2009 12:27 PM
I need your opinions! rcjunky10 Painting, Designs, Graphics and Photography 13 03-26-2008 07:10 PM
opinions austenshreds Wisconsin & Illinois Racing 1 12-20-2007 09:33 PM
Need Opinions on Tuning My NTC3! opinions on my clutch/suspenion set up needed JDMboy Nitro On-Road 0 09-21-2004 10:05 PM
Opinions about used MT-12 rod_b Nitro On-Road 4 05-22-2002 05:18 AM
