Old 01-30-2005, 03:38 PM   #1
Default Discharger for inline 6-cell
Just curious about this. I usually just run the car until the batteries die, but if conditions or time prohibit this, an inexpensive discharger may be a good idea.
So, I just use the 6-cell packs with the cells set up end-to-end, so i'm pretty sure I can't use a tray. I heard that the little alligator clamp dischargers don't do the job completely. Any recommendations?
Liko is offline   Reply With Quote
Old 01-30-2005, 04:18 PM   #2
if your using stick packs which is what it sounds like, you will need to use something that you can put a plug on,I use my GFX and then finish them off with 12 1157 bulbs,about 20 amps is all you need.
Hyper1 is offline   Reply With Quote
Old 01-30-2005, 08:26 PM   #3
Joel Lagace's Avatar
be carefull with stick packs. I would try not discharging much higher then 10amps. For a few reason:
-tamiya plugs a terrible and will melt
-typically stick packs are take welded and cannot take high amp draws
-typically sticks use lesser quality cells so cant take the amp draws.
consider them sport packs and dont use more then 10amps.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-30-2005, 10:37 PM   #4
Registered User
use lightbulbs...i use resistors..(mispell)
RC Buddah is offline   Reply With Quote
Old 01-30-2005, 10:42 PM   #5
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
It's not advisable to do this with stick packs at all, you may be reverse charging one or more cells, this is very bad indeed. If you can't discharge them individually then don't discharge them that far at all, they will last longer this way.
Chris.
crimson eagle is offline   Reply With Quote
Old 01-30-2005, 11:24 PM   #6
Hmph. OK, so I probably shouldn't use a discharger. The lightbulb thing sounded pretty good to passively discharge the batteries under load. I can take an MSC I've got lying around and clip the battery plug off and solder the wires to leads of a light board. Just get a bunch of 12V lights (or should I go lower, since the pack will be pretty dead already) and hook em in series. Or just get one bulb and a few resistors.
Old 01-30-2005, 11:33 PM   #7
Don't use anything, just leave them, if you cannot do it each invidual cell, don't do it at all.
Chris.
Old 01-30-2005, 11:40 PM   #8
Ah. Well, it was a good idea. So now I know why side-by-side packs are so popular now. When I first poked my head in this hobby, 2000mAh sticks were top-of-the-line. Things have changed in just a couple years. One of my kits should take side-by-side, maybe. The other one only takes stick, so I'll probably stick with the sport packs.
Old 01-31-2005, 12:04 AM   #9
adamkerrnz's Avatar
If the stick packs are NiCd's it is essential to discharge them before charging them again. if anybody has heard of the memory effect NiCd cells have when not properly discharged before charging.
People at my club have always been discharging stick packs to no ill effect's. we just use car tail light bulbs, around 5 of them soldered in parallel.
The only thing with bulb dischargers: Make sure you disconnect the battery as soon as the bulbs start to dim. if you leave it on there is a chance you might reverse a cell or two. the cell reversal thing only really happens when the cells voltages are way outta match. generally they are pretty close. not matched cell close but pretty close anyway.
adamkerrnz is offline   Reply With Quote
Old 01-31-2005, 05:53 AM   #10
Everybody that runs spec runs 1600 nicad stick packs and discharges with either light bulbs (20amps) or their charger (20amps) you will need to remove the tamiya plugs and replace them with deans plugs,this is standard procedure for racing with stick packs,we've been doing it for 6+ years at our track and there are hundreds of spec racers doing it right now with no ill effects.If your running NiMH's then you can leave them alone after you race, you will still need to discharge them before you charge again.But I would still advise to replace the tamiya plugs with deans plugs in all cases.
Old 01-31-2005, 06:34 AM   #11
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
here you go designed for your needs.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXUE23&P=
Edit: or this cheaper one.
http://www2.towerhobbies.com/cgi-bin...p?&I=LXHUK1&P=
Hope this helps,
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-31-2005, 07:03 AM   #12
Not sure if either of those two items will cut it.
Old 01-31-2005, 07:26 AM   #13
Well he said an inexpensive discharger for stick packs and both of them have auto cut-off so no chance of cell reversal. Why won't they cut it.
they will take the pack down to .09 per cell/avg. they are both inexpensive and easy to use without going through changing connectors and having to do anything else but connect and let it do its job.
That is good enough for regular packs so were again is the problem?
Just my two pennies,
Stephen <><
Old 01-31-2005, 08:27 AM   #14
Rob Mincey's Avatar
I don't know about the Orion stick pack discharger, but I do know that Venom cautions against using their product to discharge a full, or almost full stick pack. Apparently, it can't take the heat generated by the process.
Rob
Rob Mincey is offline   Reply With Quote
Old 01-31-2005, 08:45 AM   #15
Cole Trickle's Avatar
Default Re: Discharger for inline 6-cell
Batteries definately perform better, if discharged.
Actually, you're doing quite fine, by running your batts, till they drop, as lon as you dont over-do it and run till the car cant move anymore.
So getting an discharger or not, it depends on what you'll do in the long run.
If you want to be more serious later, you shold get cars with saddles or side-by-side packs. If that's the case, I probably wouldnt spend money on a discharger right now. If you are not sure or know it'll take a long time to get there, get that Orion discharger mentioned above. The Orion discharger will give you better control over the discharge process, since discharging in the car, will risk going to low and you get cell-reversal at some point.
If you by rules at the track are forced to use stick packs, I would get the Integy Reactor 10 amp discharger with auto cut off.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
wtb t2 007 eu spares + 4.5 motor + cell discharger khaledome R/C Items: Wanted to Buy 2 07-16-2008 02:26 PM
4 Cell Discharger corman007 Electric On-Road 3 02-29-2008 11:33 PM
Tekin 8 cell Discharger tray Goingfast R/C Items: Wanted to Buy 9 10-25-2007 05:29 PM
Spintec Discharger 6 or 7 cell $30 Tempest2000 R/C Items: For Sale/Trade 4 09-13-2007 08:18 PM
wanted...xray 6 cell inline chassis KenSmith R/C Items: Wanted to Buy 0 08-13-2002 10:41 AM
