Exoteck XR3'12
Old 04-25-2012, 12:49 PM
  #16
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by FK05 lover
Package arrived, looks good, just need time to fit it to one of the T3-12's, will see how it goes...
lucky you
OVA is offline
Old 04-28-2012, 02:56 PM
  #17
pressure's Avatar
Just came in the mail..... Sweet
pressure is offline
Old 04-28-2012, 10:17 PM
  #18
OVA
OVA's Avatar
How does eveyones like their new Exotek kit?
OVA is offline
Old 05-01-2012, 07:19 AM
  #19
pressure's Avatar
Exoteck parts went together smooth. Building second car from my parts bin so its gonna take me a couple days but all seems good to go.
pressure is offline
Old 05-16-2012, 09:14 AM
  #20
pressure's Avatar
All done gonna run it next week at indoor track high grip carpet. Not familiar with block set up looking for lowest roll center positions in rear. Which blocks should I order to go along with spacers?
pressure is offline
Old 05-16-2012, 09:58 AM
  #21
Fred Hubbard's Avatar
There isn't an option to run them in a low position like the XRAY -.75mm. We do offer 1mm and 1.5mm one-piece shims or you can use round shims. I always suggest ordering 3 of each long block so that the fronts pins can be ran straight and the front and rear track width can be ran the same as well.
Fred Hubbard is offline
Old 05-16-2012, 10:43 AM
  #22
OVA
OVA's Avatar
Hi Fred
I ran my XR3'12 last sunday for the first time,and I'm pretty happy so far...
question : what is the width differnce on the stock Xray compare the XR3 kit?
OVA is offline
Old 05-16-2012, 11:01 AM
  #23
Originally Posted by OVA
Hi Fred
Which blocks did your kit come with? When you have 3 of each long block you can achieve the same width as the kit stock front width and if you run 2.25mm (1.5mm + .75mm). The -.75mm split blocks in the rear allows you to run the Hagberg's toe mod.
Old 05-16-2012, 12:23 PM
  #24
Magnet Top's Avatar
Has anyone cut the servo nub off and used only the inside servo mount and "Shoe-Goo" to secure the servo ? If so, any regrets ? If no, any thoughts to share ?
Jake D.
Magnet Top is offline
Old 05-16-2012, 12:30 PM
  #25
MikeXray's Avatar
Trader Rating: 73 (100%+)
Jake D.
I did this on my '11 chassis while drilling a new hole for the inner servo mount, it has held up to some bad crashes without issue.
MikeXray is offline
Old 05-16-2012, 12:37 PM
  #26
Magnet Top's Avatar
The xr3 kit comes with B , C , D , and B/XB ( according to the website )
B and C in the front, and XB/B and D in the rear.
To get to the Xray kit front width ( 1.5mm with no sweep ) what is used ?
Two C's ? Two D's or Two E's ? or Two F's ?
are the steps between letters .5mm ? or ???
Old 05-16-2012, 12:38 PM
  #27
OVA
OVA's Avatar
Jake D.
Mike Malkinson did on his 2mm chassis...
OVA is offline
Old 05-16-2012, 12:39 PM
  #28
Magnet Top's Avatar
Thanks, only issue is, the exotek '12 chassis is VERY narrow, so it appears there isn't much surface area for the glue to grab to.
Old 05-16-2012, 12:40 PM
  #29
OVA
OVA's Avatar
I have to check again the blocks as soon I get home from work ..Thanks
OVA is offline
Old 05-16-2012, 01:04 PM
  #30
MikeXray's Avatar
I've seen various cars running it, seems no one wants the nub, even some home made narrow chassis It's not impossible to break loose, but it takes alot. People who just CA the edges of the servo too the chassis seem to have them break loose more often.
MikeXray is offline
