Old 01-29-2005, 06:53 PM   #1
never lift's Avatar
Send a message via AIM to never lift
Default tamiya tl-o1
i just picked up a tamiya tl-o1 does anyone have one any what are the best hop up's for it ..
never lift is offline   Reply With Quote
Old 01-29-2005, 08:07 PM   #2
PIIHB!'s Avatar
Might wanna pick up a bearing set and some better tires. Then add a better motor.
PIIHB! is offline   Reply With Quote
Old 01-29-2005, 08:47 PM   #3
Registered User
All of the hop ups other than maybe some of the carbon stuff, like the driveshaft and gear shafts will add a noticable amount to the car's performance.
On mine I found that the sway bar kit, the bearing kit, and adjustable camber links had the biggest effect as far as how the car handled and drove.
Don't jump right away and get the speed tuned gears unless your motor warrants them, I found the gear ratio to be too low for most of my stock motors, and you can't really run a 19T or lower in it without warping the motor mount.
#1 best hop up for it IMO is the bearings. Car is noticably faster, runs a little longer, and sounds smoother with them.
Desolas is offline   Reply With Quote
Old 01-30-2005, 10:00 AM   #4
Send a message via AIM to greencactus3
best hopup= sell it quick and get sumthing else.
greencactus3 is offline   Reply With Quote
Old 01-30-2005, 01:30 PM   #5
If you're taking it to the races, yeah. As a basher, this car isn't real bad.
Desolas, I of course understand the bearings (the Duratrax kit looks pretty good for half the cost of the official Tamiya kit). Does the stabilizer kit really improve performance all around or is it more personal taste as to the handling?
Also, are the aftermarket aluminum-barrel shocks worth getting right away or should I upgrade when the stock ones wear out?
Liko is offline   Reply With Quote
Old 01-30-2005, 02:38 PM   #6
never lift's Avatar
it's mostly for bashing but i will race a couple of times . what size bearings are in it i got it for 150.00 never opened up
Old 01-30-2005, 03:41 PM   #7
I think the bearing dimensions are 11x15x4. If you search for "Bearing TL01" on Tower Hobbies you'll get Tamiya's set ($70 , ouch) and Duratrax's set (a much more affordable $30).
Or, see if you can look elsewhere wholesale for two dozen 11x15x4 teflon-sealed (that's what's in both kits; I'd prefer these to metal-shielded which require more maintenance) bearings. the TL01 chassis unlike some of Tamiya's other chassis uses only one size of bearing, so it's pretty simple. Just take out all the white plastic bushings from the suspension and gear shafts and the pair of metal bushings from the pinion gear shaft and replace each one with a bearing. It requires a pretty thorough teardown of the chassis, but the teflon bearings mean you won't have to tear it down like this again for a LONG time.
Old 01-30-2005, 04:22 PM   #8
dado11g's Avatar
Send a message via ICQ to dado11g Send a message via AIM to dado11g Send a message via Yahoo to dado11g
i would get oil dampening shocks personally. i have a TL-01 but it just sits and collects dust now. i kind of made it into a raqlly by raising it and that made it a bit more fun. but now i cant use it even if i wanted to. i dont have stick packs anymore.
dado11g is offline   Reply With Quote
Old 01-30-2005, 06:25 PM   #9
never lift's Avatar
thanks Liko i have a wholesale bearing place 20 min's from me i'll check there tomorrow. i see most tires are 26 mm and the tlo1 has 27mm will the smaller rims fit on the car
Old 01-30-2005, 06:53 PM   #10
PIIHB!'s Avatar
Just get a bunch of 5x11 bearings.
The tire measurment is the width. Almost all rims will fit the car.
Old 01-30-2005, 07:33 PM   #11
never lift's Avatar
i'm going to see if my 4-tec shocks will work on the car
Old 01-30-2005, 08:39 PM   #12
thats why you should sell those springs to me dead cheap.
and you can mill out a lot of weight from the chassis if you wanted. saw an insanely swiss cheesed tl01 pic on rcdrift.com lotsa people use tl01s there.
Old 06-24-2005, 10:20 AM   #13
Location: San Mateo, CA (20 miles south of San Fransisco)
Send a message via AIM to KevinO1211
Talking
Yeah, I have a lot of fun with mine, I was going to sell it, but my dad has way too much fun with it. What do I need to do to prepare it to handle a 19t motor? It already has an ESC.
KevinO1211 is offline   Reply With Quote
Old 06-24-2005, 01:42 PM   #14
never lift's Avatar
Default tl-01
bearings / speed tuned gear set /oil filled shocks . differant tires
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
