Old 01-29-2005, 12:22 PM   #1
Default Best batteries for Stock Racing
What are the best batteries for stock racing (with a lot of punch)?
darulor is offline   Reply With Quote
Old 01-29-2005, 12:25 PM   #2
okay everybody with battery sponsors list them
pony klr is offline   Reply With Quote
Old 01-29-2005, 12:26 PM   #3
koabich's Avatar
Send a message via Yahoo to koabich
Any battery from a reputable matcher that has high voltage numbers and low IR numbers. Batteries matched at a 30 amp discharge in the 1.180+.
koabich is offline   Reply With Quote
Old 01-29-2005, 12:28 PM   #4
shameless plug www.teampowerpush.com
Old 01-29-2005, 12:56 PM   #5
dakrat's Avatar
Default Re: Best batteries for Stock Racing
dont matter if ur running stock or modified. u still want the punchiest packs
dakrat is offline   Reply With Quote
Old 01-29-2005, 02:44 PM   #6
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
all the way!!Pro Match Racing
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-29-2005, 03:03 PM   #7
Send a message via AIM to rcguy2477
Fusion packs are good.
If you're not too sure on your soldering skills, you can get them prebuilt.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 01-29-2005, 06:06 PM   #8
Jack Smash's Avatar
Trader Rating: 29 (100%+)
SURGE WORLDWIDE
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-29-2005, 07:38 PM   #9
Kinda....
If you want to be fast the you want the BEST packs you can get from any matcher you like. They all do something different so you can't compare numbers. The best packs any particular manufatcer has will be similar the the best others have.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-29-2005, 07:48 PM   #10
t4usee's Avatar
It's simple.
www.fusionbatteries.com
Team Fusion
Team Tekin
BKPaintwerks
t4usee is offline   Reply With Quote
Old 01-29-2005, 08:38 PM   #11
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wait till the Intellect 3600 cell comes out.. these will be the best for stock racing!!.. lots of punch... and very low IR
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-29-2005, 09:40 PM   #12
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
I usually go for run time, as long as the voltage is over 1.165 I'm happy but run time is king. You really need to think about how the voltage slope works in discharge. A 1.185 average voltage cell sounds good but if they only have 390 seconds of run time, at 400 seconds the voltage is zero. If you have 435 seconds cells then at the end of the discharge (race) you will have better voltage as you will be further back on the discharge curve.
As a note on equalising - do it and take them down to 0.0v every time. You will get more run time by discharging to zero volts rather that 0.8v (24 seconds on averager according to a tests performed by Pro Trak). I'm not convinced of the effectiveness of dead shorting, there have been varying results, sometimes a reduction of run time.
Chris.
crimson eagle is offline   Reply With Quote
Old 01-29-2005, 11:21 PM   #13
Registered User
get the best batteries u can afford..make sure to get about 3 packs too
RC Buddah is offline   Reply With Quote
Old 01-29-2005, 11:39 PM   #14
AdrianM's Avatar
Run run my old mod packs in stock and 19T. When the run times aren't good enough for Mod they are great for stock. After a few months of Mod runs the IR gets lower and the voltage gets higher.
I under stand about discharge curves and the theory that you still need runtime for stock to stay in the higher voltage portion of the curve but when I cycle a 350-360 sec pack at 30A it will hold 7v+ for 300 sec. 300sec of good voltage is all you need.
Adrian Martinez
Old 01-30-2005, 12:01 AM   #15
Hi Adrian,
Believe it or not we do have a few people at our club dumping in 12th stock. Personally I like to see the voltage at 5 minutes under a 30A discharge for judging a stock pack, that and runtime works good for me but i always buy for run time. You know you can use run time packs for anything, but high voltage and only low runtime you can only really use for stock, they will not match uo in Mod.
I met you a few years back at Stockton or Ripon CA. If you could check out my website below I would be interested in your opinion. (CDAT website).
Thankyou.
Chris.
Which batteries are thhe best for stock Gavtec Australian Racing 10 12-19-2004 09:10 AM
best batteries for stock racing Snippy Rookie Zone 17 09-13-2004 09:11 AM
Batteries, Batteries, Excellent for Stock! Thunder3 R/C Items: For Sale/Trade 6 09-01-2004 04:25 PM
Stock TC Batteries? timc Electric On-Road 9 03-06-2003 03:28 PM
