Old 04-03-2012, 02:06 PM   #1
Default losi xxx s parts?
i just got a losi xxxs with a new yellow xxx4 belt on it and the belt is to big where can i get a xxx s belt?
Uploaded with ImageShack.us
cloudstrife is offline   Reply With Quote
Old 04-03-2012, 03:51 PM   #2
redbarton's Avatar
Try this:
http://www.losipartshouse.com/servle...h-R/Categories
redbarton is offline   Reply With Quote
Old 04-03-2012, 03:54 PM   #3
Trader Rating: 24 (100%+)
Here's what you need. Once you have the correct tensioner you'll only need to buy belts later on.
http://www.ebay.com/itm/Losi-Heavy-D...item2a146aa07d
Doesn't look like Losi partshouse has the xxxs black belt and tensioner.
Evoracer is offline   Reply With Quote
Old 04-07-2012, 02:27 PM   #4
so if i get the tension arm parts for the losi xxx 4 it would work with the belt i have on the losi xxx s?
Old 04-07-2012, 04:10 PM   #5
I'd just go ahead and spend the 20 bucks for the tensioner/belt combo. I've come across many a xxxs with some weird belt on it. The "long" Losi black belt was 777mm long. You can check that against your Yellow belt. The long tensioner arm is an absolute must with the long belt. I don't even know if you can get the arm without the belt. Yes, you can buy belts alone.
Old 04-07-2012, 06:00 PM   #6
thats what i wanted to know
Old 06-01-2012, 02:19 PM   #7
I just recently picked up a XXX-S also and purchased the xxx-4 belt and tensioner you listed above. I installed it last night and adjusted the tensioner as tight as I could and the belt jumped when I drove it. Is there a way to tighten it more?
jetroc0088 is offline   Reply With Quote
WTB: Losi XXX-S Parts Whatchamacallit R/C Items: Wanted to Buy 6 06-08-2007 08:59 PM
Losi XXX-S Parts CHEAP - NIB RichO R/C Items: For Sale/Trade 7 11-08-2005 06:03 PM
