Old 07-09-2013, 08:11 PM   #76
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Originally Posted by JustWill75 View Post
What's the opinion on the R1 WURKS fan? I just got one but have not tested it yet.
That is what I am using! I like them but willing to try to boost the cooling power.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 07-09-2013, 08:19 PM   #77
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Francis M. View Post
Probably blows more air because it's direct wired....
Of course, running more voltage. Not sure if the R1 Works fan is rated for 8.4V but it'd be interesting if someone had time to compare them back to back.
Dan is offline   Reply With Quote
Old 07-09-2013, 10:25 PM   #78
Hmmm you seem to have both fans....
Maybe ask R1 Wurks if their fan can run at 8.4v without self destructing.
Sydewynder is offline   Reply With Quote
Old 07-10-2013, 05:28 PM   #79
R1wurks's Avatar
Default New R1 wurks 8.4v fan
R1 8.4v fan coming soon
r1wurks.com
r1wurks at gmail.com
R1wurks is offline   Reply With Quote
Old 07-11-2013, 11:44 AM   #80
Michael@USPN's Avatar
Holy craaap! The best fan just got better!!! Put me down for all my cars!!! Now even more timing! lol
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 07-11-2013, 12:26 PM   #81
F. Mendoza's Avatar
Very nice! I will have to get two new fans in the near future!
Old 07-11-2013, 12:52 PM   #82
silden's Avatar
The picture looks promising, but is the ampdraw really 5.1A?
This sounds a lot for a small fan.
silden is offline   Reply With Quote
Old 07-11-2013, 01:23 PM   #83
R1wurks's Avatar
http://youtu.be/iQ3-Sz0kkRI
r1wurks.com
Old 07-11-2013, 01:53 PM   #84
silden's Avatar
OK the 0.5 Ampdraw is much better than the 5.1 shown on the first picture.
Old 07-11-2013, 03:08 PM   #85
Dan
Dan's Avatar
The picture is showing an adjustable power supply that is supplying power to the fan. Not reading off output.
It is supplying 8.4V to the fan, which is normally the battery output when fully charged. The current was adjusted to 5 amps, which is probably what would be put out in a normal setup.
Old 07-11-2013, 04:09 PM   #86
silden's Avatar
I've assumed this as saw the picture, but I asked to prove it.
BTW there are some server fans out there with a current flow of 2+ Amp.
Old 07-11-2013, 04:42 PM   #87
theatriks's Avatar
Does any body have video of the superior hobby fan.....at 30 dollars a fan I would like to see what I'm getting first lol
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 07-11-2013, 04:51 PM   #88
R1wurks's Avatar
Superior hobbies fan
http://youtu.be/WXJ9tL-BqDk
r1wurks.com
Old 07-13-2013, 12:42 PM   #89
F. Mendoza's Avatar
Originally Posted by Stratus Racer View Post
I've seen a lot of racing dropping the heat sinks lately. A few even made side walls from lexan to guide air to the motor. Some made ducts to vacuum air from the motor. I even made a duct to extract the air. If time permits I'll snap and post a picture after work later today. I will test it Friday, I hope.
This is what I came up with after seeing a few guys making enclosures for their fans. This one is pretty much air tight at the edges where I was able to seal it with carbon fiber sticker I did. On one side I put a bit of foam and it sits on the chassis. It should or, at least I'm hoping it will vacuum air through the holes outside of enclosure, through the motor, and through the fans. As you can see the other motor is still soldered to the ESC. I will run this with and without the fans to see what results I get on Friday. I'll update afterwards with results. Hope it works.
I went up twice and the temp stayed at 127-137 on all three runs of 7 minutes.
Old 07-16-2013, 01:40 PM   #90
seth556's Avatar
Trader Rating: 42 (100%+)
Any reason why your video is 24 seconds long and the Superior fan is almost 5 minutes long? Did your fan not make it 5 minutes? Also it appears that you're holding the fans at different distances away from your scale, you should really build a jig to hold the fans over the scale to get a more accurate reading instead of just guessing at how far away your holding the fans.
seth556 is offline   Reply With Quote
Whats your favorite heat sink?? Little John Electric On-Road 21 06-13-2013 08:36 PM
WHATS THE BEST FANS? 16skyline Electric On-Road 6 03-12-2008 12:04 AM
