Old 02-27-2013, 09:50 AM   #46
hanulec's Avatar
Trader Rating: 27 (100%+)
The data sheets don't tell the story. I buy random fans all of the time looking for the next one....
Generally all of the cfm ratings from vendor to vender differ.
I guess I'm going to have to start looking at 3 wire fans
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-27-2013, 09:58 AM   #47
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Pygmy View Post
Do you happen to know of a manufacturer (not a hobby reseller) that makes fans with these specs ?
No I have not looked at any of the specs of any fans to be honest. I hook them up, do the feel test and go from there. I know at the birds my motor was running what I thought was border line hot. Robbie from Superior came over and told me I needed to at least try one of his fans. He showed me one on someone else's car and it did move much more air than what I was using so I bought one. Motor temps went down about 20 degrees from a fan change.
He later said that he had to buy some crazy amount of them as he had them made to his specs. I know he had several thousand of them at the shop boxed up so I would assume he probably wasnt BS'ing about having them made. If they were something easy to get he wouldnt have bought that many at one time I am guessing.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-27-2013, 10:42 PM   #48
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Originally Posted by EAMotorsports View Post
For a 25mm fan nothing beats the Side piece racing fans. If you want a 30mm fan that you can wire directly to a speedo (battery) nothing beats the fans that Superior hobbies has. Its like a tornado in your car. Ive not had a fan move that much air before. I believe he said it was 12-15 cfm's but I cant remember exactly....it is bigger and heavier though than the Side Piece racing fans that work awesome for ones plugged into a receiver. It moves more air off of 5 volts than most do off of 8.4 volts except the superior hobbies fan.
EA
Just placed order! I will take your word for it! Have been using Team Powers 40mm fan wired to speedo. Its OK but always looking to improve!
Josh-n-ya is offline   Reply With Quote
Old 03-01-2013, 03:05 AM   #49
Pygmy's Avatar
EA
Ok, I guess I'll have to order one then
I do think the price is pretty steep though. Normal good high airflow fans are $5 - $8. $15 for a really good one would be okay. But $30 for a 30mm fan ? Wow
Apparently he sold a lot 'cause if he had thousends, the site now says there's only 26 left in stock.
Cheers !
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 03-08-2013, 12:30 PM   #50
Zeppin 30mm fan is good, but it is not comparable to Yeah Racing's.
Zeppin's 40mm fan is a bit better than R1Wurkz's but nothing to lose sleep over.
I have yet to test Superior Hobbies's. I'll report back when I do.
Serpenteer is offline   Reply With Quote
Old 03-15-2013, 01:19 PM   #51
Pygmy's Avatar
I have to apologize for calling fans "creatively specced".
I just received the Zeppin 30x30x10mm fan and holy shit does that thing move air !
It moves a lot more air than my own 30x30x15mm fan. Back to the drawing board
How so ? Zeppin's rated at 8.5cfm, Yeah Racing Tornado at 5.5.
Old 03-15-2013, 01:41 PM   #52
Yeah Racing's throw 3.5g-3.7g on a scale. Zeppin was struggling getting up to 2g.
I would love to go by what the specs say. They just never hold true. I have over 10 fans, Yeah Racing is still top of the hill. The Zeppin's 40mm is a contender for its size.
Old 03-18-2013, 09:20 AM   #53
Pygmy's Avatar
Ordered 3 tornado's as well
Old 03-18-2013, 02:20 PM   #54
SS LS1's Avatar
Trader Rating: 23 (100%+)
That's Cool, (LOL pun intended) please give us feedback compared to your new Zeppin 30x30x10 fan.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 03-18-2013, 03:42 PM   #55
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
After having the rspro thermal twice this weekend i think ill look into some delta fans. 40x28 should the trick if it fits. 25 cfm which still
Low compared to the larger pc fans i deal with ha.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 03-18-2013, 06:11 PM   #56
Josh-n-ya's Avatar
Very pleased with Superior Hobbies fan. Finally tested this weekend. Was worried cause I was always on the verge with my Team Powers fan at 150 degree range. Same set up and gears temps went down to 125 degrees. Will gear a bit higher next week and test.
Old 04-05-2013, 07:11 AM   #57
Pygmy's Avatar
I put the Zepping 30x30x10mm on my Hobbywing SCT Pro Esc, put my car on the track, took the first jump and then I found the fan-blades lying on the track after the landing.
So I think their description :
>Up to 20000 hours lifetime (mounted on staple surface)
actually means "mounted on stable, solid, non-moving, shock-free surface"
Old 04-05-2013, 10:01 AM   #58
Skiddins's Avatar
Probably because the PC fans you deal with are 12V
I have two large boxes filled with various PC fans from 40mm to 120mm right beside me now. None are any use for RC.
Putting my current NMB 5V 40mm fan near a small scale I can get over 10g, it's rated at 8.2cfm.
Skiddins
P.S. I think that some of these cfm ratings for 30mm fans people have mentioned are in fantasy land, or their mistaken.
Over 8cfm for a 30mm sounds highly unlikely, can someone measure on the scales please
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-05-2013, 10:15 AM   #59
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
The Superior Fan is awesome! Got two, tested last weekend, 25 degrees difference.
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 04-05-2013, 05:57 PM   #60
Josh-n-ya's Avatar
Just dont tell your competition! They are fantastic!
Whats your favorite heat sink?? Little John Electric On-Road 21 06-13-2013 08:36 PM
WHATS THE BEST FANS? 16skyline Electric On-Road 6 03-12-2008 12:04 AM
