Old 04-02-2012, 03:40 AM   #1
mondragon's Avatar
Default run time
hey guys, ive put together an X12 4.5t lrp with lrp spx esc using turnigy 4000mh lipo for my serpent s400, im only getting a few minutes runtime?! can anyone let me know is there a lipo out there for this or is it the engine?
mondragon is offline   Reply With Quote
Old 04-02-2012, 06:29 AM   #2
MrUnlimited's Avatar
Gearing or your charger cannot charge the lipo to its potentional.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-02-2012, 07:34 AM   #3
locked's Avatar
I've drained a 6000mah battery in around 8 minutes with a boosted 5.5 outdoors on a larger flowing track.
Low turn motors can draw a lot of power. If you are doing speed runs, a few minutes out of a 4000mAh battery sounds about right.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 04-03-2012, 03:38 AM   #4
mondragon's Avatar
thanks for the reply- I think the batteries I'm using don't have the required discharge rate. any advice as I'm using the lrp spx esc, the specs have it at 400A/phase. Thanks again
Old 04-03-2012, 04:18 AM   #5
alcyon's Avatar
you would be better off using a 10.5T motor and use boost and turbo to get the top speed. and you will be a lot easier on your batteries abnd your car too. i think 4.5 is just way too much power, even if you have a 6000mah battery.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 04-03-2012, 04:51 PM   #6
mondragon's Avatar
Thanks for your reply,I'll grab a 10.5t. this will allow me to turn punch
up thru esc no problem?
Old 04-03-2012, 11:08 PM   #7
alcyon's Avatar
Not sure about your esc, but the hobbywing v2.1, orca vritra mk2 and Tekin rspro all has these boost and turbo function.
10min+ Run Time Engines? RCRACER2X Offroad Nitro Engine Forum 131 12-30-2010 09:12 PM
your engine and run time?? jmaxey51 Offroad Nitro Engine Forum 61 11-26-2010 03:50 PM
What engine if I want long run time and have $200 Klimpen717 Offroad Nitro Engine Forum 66 10-25-2010 10:58 AM
Mamba monster run-time in 1/8 buggy Chatzstuff Electric Off-Road 12 07-15-2010 04:39 PM
Run time on GP 3300's? 429racer Electric On-Road 47 11-28-2003 06:04 PM
