Old 01-27-2005, 02:56 PM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Comparing different manufactures springs
Is it possible to compare different manufacturers spring via some conversion factor?
I have some springs that I believe are rated in something like "kg/s" and i want to compare them to some AE springs I have which are in "lbs".
Thanks.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-27-2005, 06:06 PM   #2
http://www.rcingreece.com/index.asp?...ing_comparison
MManson is offline   Reply With Quote
Old 01-27-2005, 07:50 PM   #3
Tech Legend
Cain's Avatar
Thanks for the info. What does gf stand for?
my springs are Academy springs and have these ratings:
1.8 kgs
2.2 kgs
2.8 kgs
anyway to convert these?
Old 01-27-2005, 08:46 PM   #4
www.onlineconversion.com
Old 01-28-2005, 06:40 AM   #5
Tech Legend
Cain's Avatar
anyone know what gf stands for?
I know that the springs won't be a direct conversion to lbs as they are alot stiffer than what the conversion would say.
Old 01-28-2005, 08:06 AM   #6
Rick Vessell's Avatar
gf is gram force, usually per square mm.
to convert spring rates in gf/mm to lbs/in multiply by .0559968.
ex. 200 gf/mm * .0559968 = 11.2 lbs/in.
sounds like academy is using kg/cm which would be a stiffer spring rate than a gf/mm rating. just use the kilogram force - pound force conversion on online conversion to get the conversion factor.
enjoy!
Rick Vessell is offline   Reply With Quote
Old 01-28-2005, 09:56 AM   #7
Tech Legend
Cain's Avatar
So basically I will just mutiply the kg that I got from Academy by
5.59968 or 5.6 approximately.
so my spring rates then are:
1.8kgs = 10lbs
2.2kgs = 12.3lbs
2.8kgs = 15.7lbs
Thanks for the info guys. So basically I got some 10, 12, and 16lbs springs on a rough estimate. These should work well with the other sets I have then from AE as I got from Red up to yellow from them. Just need Gold and I will have a great usable range ( never did use 40lbs fronts ).
Thanks again for all your help guys!
Old 01-28-2005, 11:02 AM   #8
Tech Legend
Cain's Avatar
I got some other info here from another board:
"I believe the measurement you have is kilogram-metres
The conversion you want is foot-pounds
To convert kilogram-metres to foot-pounds multiply by 7.233
So, 1.8 * 7.233 = 13.0194 ft/lbs which would not be unusual for a Touring Car. Off the top of my head I believe that is what the Blue AE TC3 spring is rated at."
I wonder if this is correct?
who manufactures carpet. kerry Electric On-Road 14 07-07-2015 05:04 AM
AnyOne with info on the Manufactures Cup Matt M. Nitro Off-Road 5 08-06-2008 12:36 PM
Foam tyre manufactures ioxqq Nitro On-Road 16 04-13-2007 10:47 AM
2005 Manufactures Duel number_0 Racing Forum 3 04-19-2005 06:56 PM
ft tc3.......yokomo springs.......integy springs......xray springs Dave Bowser R/C Items: For Sale/Trade 0 03-06-2004 03:42 AM
