Old 03-29-2012, 03:05 AM   #1
Default Electric motor without magnet
Is there a motor without the magnetic forces in the rotor that runs free? I know i can just run a X12 a couple of times with too much timing but is there some other way around?
Foodie is offline   Reply With Quote
Old 03-29-2012, 03:18 AM   #2
42 is the answer
Tamiya DB01R - TRF201 - TRF201 - TRF801X - TRF801X - TRF416X - Associated RC12R5
Fast04STi is offline   Reply With Quote
Old 03-29-2012, 04:07 AM   #3
Originally Posted by Fast04STi View Post
42 is the answer
and wetwang is the centre of the universe
sidecarphil1 is offline   Reply With Quote
Old 03-29-2012, 04:18 AM   #4
Not in electric...electric motors all use magnetic forces of some kind. Nitro engines are non-magnetic.
I think i know what you mean though in that you are concerned that the magnetic forces may slow down the motor too much...the old brushed motors were much stronger in that effect and was not really an issue. If your car is slowing down too much now it is more likely due to binding in the drive trane somewhere and not due to strong magnetic forces in a BL motor.
Old 03-29-2012, 05:13 AM   #5
Regional Moderator
CarbonJoe's Avatar
A smaller diameter rotor, or a weaker rotor will both reduce the effect you are seeing. The X-12 motors have very strong rotors, so when you turn them by hand, you can feel the "notchyness" as it rotates. Thus, when you lift off the throttle, it adds some natural drag brake.
Increasing the air gap by using a smaller rotor will reduce this, at the expense of slightly less torque (but more RPM). The air gap is the distance from the rotor to the stator. You can get the same results with a magnetically weaker rotor.
Depending on the ESC you are using, you can also reduce the drag brake setting, or add push control, which applies a small amount of throttle to counteract this effect.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-29-2012, 07:30 AM   #6
Are you familiar with how an electric brushless motor actually works?
42 is the answer
I disagree. 71 is the clear choice
JamesL_71 is offline   Reply With Quote
Old 03-29-2012, 08:31 AM   #7
The very first generation of brushless motors did not have much magnetic force in them and its actually because i run RC Bikes and you want as little magnetic force as possible. Thats why i ask... I cannot buy 20 different brushless motors and try out myself.
Btw. drag brake is on 0%
Old 03-29-2012, 09:05 AM   #8
An induction or asynchronous AC motor would not have permanent magnets in the rotor.
MHR
Highside20 is offline   Reply With Quote
Old 03-29-2012, 09:06 AM   #9
Rick Hohwart's Avatar
The Thunder Tiger Europe bike team uses Reedy motors with good results. The drag brake is not severe and the powerband is very smooth.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 03-29-2012, 09:07 AM   #10
Have tried to run a Tekin? They have a setting called push that might do what you are looking for.
MHR
Old 03-29-2012, 09:26 AM   #11
Some of the early Feigao motors had almost no magnetic 'drag'. Unlike the current designs of BL motors, those early motors did not have an iron core with the stator wires wound around it. They just had loops of wire crammed into the can with no core. So, no magnetic drag as long as there was no current flowing through the stator coils. Something like these motors: http://www.rc-monster.com/proddetail...WAND_XL&cat=20
Of course, they also aren't sensored. Don't know if you'll find a sensored motor with no magnetic drag. If you really need sensored, then Highside20's suggestion of using a Tekin with push control is your best bet.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 03-29-2012, 09:53 AM   #12
DesertRat's Avatar
A multi-phase induction motor has no permanent magnets and therefore has very little freewheeling resistance, but good luck finding one of those at your local hobby shop.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 03-29-2012, 10:52 AM   #13
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
was going to say thers r no mag motors out there but not our size.
I could be done for rc just dont know how useful or effective it would be for our needs.
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 03-29-2012, 11:34 AM   #14
no you are wrong my good friend 42 is always the answer , 71 is clearly a crazy number dreamed up by mad rabbits
Old 03-29-2012, 03:04 PM   #15
wingracer's Avatar
Trader Rating: 24 (100%+)
Actually, I believe it was George Carlin that came up with 71. Let's just say it is related to 69
As for the motor question, get a Tekin, use push control and any motor you want. Between push and drag, you should be able to get any off throttle feel you want.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
1/10 electric Offroad racing at Keilor rc1b4 Australian Racing 12189 10-18-2017 05:13 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
