Old 01-27-2005, 01:57 PM   #1
mcc-bri's Avatar
Default Dry bearings
My bearings on my tc3 keep drying out and i heard of people using motor oil to lube em up, anyone use motor oil?
mcc-bri is offline   Reply With Quote
Old 01-27-2005, 02:11 PM   #2
nmt6789's Avatar
Send a message via AIM to nmt6789
I think there is a special bearing lube....
nmt6789 is offline   Reply With Quote
Old 01-27-2005, 02:21 PM   #3
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Air tool oil is great for bearings. Good anti scuffing properties. I use Marvel's.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-27-2005, 02:22 PM   #4
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
dang i need to oil my bearing then i sprayed them out last night and but them back on with out lubing them ? what would happen if i use them like that?
Roberto Falcon is offline   Reply With Quote
Old 01-27-2005, 02:25 PM   #5
nmt6789's Avatar
Probably nothing, just might not be as smooth.
Old 01-27-2005, 02:29 PM   #6
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Ive heard of a good motor oil to use. Its called Marvel Mystery Oil. Its the oil, not the additive. I hope this helps. You want oil as thin as possible so it wont cause more friction. If you use oil you gonna have to clean them and re lube them more often. Cause the oil comes out faster than grease.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-27-2005, 02:41 PM   #7
John_S's Avatar
if you dont lube ur bearings they will heat up and will not last as long, a good oil is trinity royal oil
John_S is offline   Reply With Quote
Old 01-27-2005, 02:44 PM   #8
nmt6789's Avatar
isnt marvel mystery oil basically after run oil?
Old 01-27-2005, 03:33 PM   #9
mcc-bri's Avatar
I had already cleaned the greace out of my bearings and used motor bearing oil in them but there dry now
Old 01-27-2005, 03:38 PM   #10
put oil back in them. Oil makes your car freer. Every once and a while check the grease in the diffs and clean the entire diff, fron and rear. and check for any messed up bearings.
ProMatchRacing
Team Corally
Superior Hobbies
Old 01-27-2005, 03:39 PM   #11
mcc-bri's Avatar
so i guess i will stick with motor bearing oil
Old 01-27-2005, 03:44 PM   #12
Jack Smash's Avatar
You need oil in there to help keep the parts cool and the oil helps move the contaments away from the moving parts. A oil free bearing will be free due to less drag but will not last long. Do not use Motor oil, it has additives in it that aren't really suited for use in a ball bearing.
After run oil is generally the same as Marvel Mystery Oil. I use Marvel air tool oil because it has been formulated with better anti-scuffing properties (helps bearings last longer) and is thinner.
Old 01-27-2005, 06:02 PM   #13
sewing machine oil
MManson is offline   Reply With Quote
Old 01-27-2005, 06:06 PM   #14
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Tribo if you can find it. It is a bearing lube, comm drops and swivel stand lubercant. It is thin and is probably is the best stuff out there. Just my $0.02
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-27-2005, 08:12 PM   #15
Registered User
use motor oil or something, that would work..tried em on my bearings and were so smooth after that.
RC Buddah is offline   Reply With Quote
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Looking for TC3 bearings Mnster R/C Items: Wanted to Buy 8 01-05-2006 12:51 PM
TC3 Bearings Ridge_Racer Rookie Zone 17 12-22-2005 09:16 PM
Bearings karter Electric Off-Road 2 05-08-2004 03:43 PM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
