Old 11-27-2005, 06:56 PM   #61
Barry W's Avatar
I have heard from others, this car feels well with an associated 70 up front, and 60 in the rear.
Although these are approximates. Try this out, and see how it runs.
Corally Carpet Spec RDX
CRC Bloody Carpet Knife 3.2R
Tamiya M-04
www.pmhobbycraft.ca
Barry W is offline   Reply With Quote
Old 11-27-2005, 07:13 PM   #62
Taz_S's Avatar
hey did any one try to see if you could use the x-ray front one way or spool? Not the 05'
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 11-27-2005, 08:22 PM   #63
the pig's Avatar
Send a message via Yahoo to the pig
Talking
taz , t-bone here run at least 50 oil and run purple fronts, blue rears(losi springs) whatever they match up with from xray or mugen. hit me up for your parts order you got my#
the pig is offline   Reply With Quote
Old 11-28-2005, 09:51 PM   #64
the pig's Avatar
good to meet you and welcome to airborne-models there are alot of things to come soon.
Old 11-29-2005, 05:18 AM   #65
Company Representative
I can only think of 3 items I would like to see for the car,
1. caster blocks in 2 and 6 deg.
2. additional sway bars
3. additional rear toe blocks
Guess who's decided to play again???
HB Racing/Team Orion
Gary Fliegel is offline   Reply With Quote
Old 11-29-2005, 07:39 AM   #66
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
not sure if this has been asked, but how is the car on foam tires?? Is it "foam friendly"?? some of the chassis' have issues with the wider foam tires (i.e., Tamiya 414, 04, EvoIII series) so you need to use spacers to get the wheels from rubbing on the camber links...
so has anyone tried running foams with the car??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-29-2005, 10:16 AM   #67
Tamiya's old suspension has no problem with foam tires. You may have to buy the aluminum rear hubs which is recommended anyway.
Juan Aveytia is offline   Reply With Quote
Old 11-29-2005, 10:29 AM   #68
Barry W's Avatar
I have mounted Jaco 28mm's and the front wheels are close to the camber links. But they will not rub with those wheels.
As far as parma's or GQ's I haven't tried them yet.
Tamiya M-04
www.pmhobbycraft.ca
Old 11-29-2005, 01:40 PM   #69
k_bojar's Avatar
not sure which one you are refering too, but I know that 28mm tires will rub against the camber links on the 414/04-style suspension - even when using the 6mm clamping hubs....
I've been running tamiya's 04/414 suspension since the 04R came out...and every foam tire I've run rubbed to a certain degree - and I've used spacers as well...
Old 11-29-2005, 02:55 PM   #70
I never made any modifications on my 414,415,evo3 with the old suspension to mount foams on. EJ Evans is a local tamiya driver. By the way his original 415 is dialed. He use's the original suspension with it. No modifications needed to run foams.
Bojar your not using the caster blocks where the plastic sticks up really high on the top? Those caster blocks usually came with the plastic ta04 car kits.
Old 11-29-2005, 05:33 PM   #71
the pig's Avatar
can use spacers on front but if you do middle hole on a arm then bring in the tops to 2nd from outside the car will handle the foams better. with so much traction you also need to stand up rear shocks as well. one in on a arm then 1 or 2 in on tops. 50= oil is needed with at least 23lb fronts aned 17lb rears to start off with then go from there as everyone drives diffrent then everyone has own setup. good luck
Old 12-03-2005, 05:02 AM   #72
Anyone know if this company has plans on making a car with the Tamiya 415/ X-Ray FK05 chassis layout. If they could deliver this newer chassis design for a price even close to this 707R it would be a steal, not that this car isn't a steal, but I think they would probably sell a grundle if it had the newer chassis layout for a price under $300. Too bad the 707R didn't come out about two years ago for this price, it would have put this company on the map! Nice looking car for the price though, looks like it would be fairly easy to do maintenace on as well with the easy axcess diffs. Curious to know if most of the Tamiya car and 04 X-Ray parts would fit, allowing the use of Tamiyas DJ Pro Module rear suspension setup for instance, I heard this can be used on the older 414 cars even though it was made for the 415.
WailinOnYa is offline   Reply With Quote
Old 12-04-2005, 01:05 AM   #73
Barry W's Avatar
I was told things are in the works for the chassis and lowering of the spur/re-designing of the rear bulkheads.
Tamiya M-04
www.pmhobbycraft.ca
Old 12-04-2005, 01:21 AM   #74
So far TA04 front and center one-ways fit. I plan on trying xray spring steel hub axles, as they are much stronger, and seem like a good fit.
MarchTC3 is offline   Reply With Quote
Old 12-11-2005, 04:19 PM   #75
Taz_S's Avatar
when can we get those battery hold down that are on the setup sheet?
Max Racing MX-707R Still Around? drbelleville Electric On-Road 2 03-17-2008 02:16 PM
Max Racing MX-707R thekthai Singapore R/C Racers 0 09-23-2007 08:20 AM
MAX RACING MX-707R gotyournumber R/C Items: For Sale/Trade 1 09-17-2005 03:32 PM
New Max Racing MX-707R Tourer danjoy25 Electric On-Road 2 08-20-2005 10:54 AM
mx-707r saw it in a magzine snaponjunky1 Electric On-Road 8 03-27-2005 06:12 AM
