Max Racing MX-707R
#31
keep the price the same and get a spool for it. I might pick one up.
my lhs is http://www.jphracing.com/
#33
that is all months down the road and also depends on the bigger response we get from 707r. most of all pricing will always stay moderate like it is . a spool can be made as easy as not putting in balls then replace with small rubber disks then put together tight no you have a spool. the other ways is to epoxy together instead of only screw. where ever you are i can ship to you asap and supply you with parts until your local hobby gets them.
#34
#35
listen to this guy he knows his stuff well.
#38
see you there
#39
welcome to world of max racing. setup sheets will be posted here for a while till website gets going. anybody outside of the u.s please get a hold of me.
#40
Ill scan some setup sheets tomorrow. Larry if u need some graphics for the site I can help you out.
#41
this will be a true grass roots team so any input is great
#42
Blank setup sheet.
#44
Will do when I get some more behind the wheel time. So far im running the out of the box setup, and it seems pretty good. Ill post that up soon.
